CS5.5 deployment now has me on my last leg. I've now tried every method to deploy this and still have no resolution.
I've tried:
* uploading the DMG into Admin and using the "this contains an Adobe installer" - This freezes with our proxy prompt for updates
* using the adobe application manager to create pkgs of each install - each time I try to install I get a permissions error
* packaging the install and running a script to execute - always fails with an unknown error
* using Composer to capture and deploy - For some reason it shows each app as having a CS5 version and then the updated version (CS5.5) and all apps crash
Any help would be incredibly helpful. I've got about 20 machines I need to build and at this point it's looking like I'm better off installing manually on each system.
Thanks,
Noah Swanson
Imaging Specialist
Enterprise Desktop Services
Phone: 309-765-3153
SwansonNoah at johndeere.com
