Hello,
Our JAMF API integration has been working fine for a few years now, but suddenly its stopped working
I've done two things to try to make it work:
1. Changed passwords to be 15 characters
2. Enabled "Allow Basic authentication in addition to Bearer Token authentication" in settings > system > password policy
But still we are getting 401 unauthorized.
Here's our code
Set creds = "%username%:%password%"
Set base64 = base64 "%creds%"
HTTPHEADER "Authorization", "Basic %base64%", "string"
Set tokenjson = HTTPSEND "https://%domainname%/uapi/auth/tokens",  "application/x-www-form-urlencoded", ""
And we also tried to get a bearer token, with the same issues
Set tokenjson = HTTPSEND "https://%domainname%/api/v1/auth/token", "application/json", ""
As I said this was all working, so I don't think there's anything wrong with the code, any ideas ?
Be the first to reply!
