Best method for monitoring Mobile Device Apps
  • July 9, 2024
  • 4 replies
  • 39 views
Hi everyone, please, what is your best method to retrieve the uninstallation figures of a Mobile Device App in a dashboard, in order to monitor this ?
mvu
Forum|alt.badge.img+21
  • July 9, 2024
Create a Smart Device Group with the app criteria.
Check off the box "Show in Jamf Pro Dashboard." I also check off the box "Send email notification on membership change" to get emails.
  • July 9, 2024
Hi @mvu
I knew the method you gave me, but thank you anyway :)
My question is more precisely to retrieve the number of uninstallations of a Mobile Device App in a Dashboard or other table.
mvu
  • July 9, 2024
Hi @mvu
Whoops. Could you duplicate that Smart Group, and change the criteria to "does not have"? This way you can compare the two Smart Groups and pull reports.
  • July 10, 2024
@mvu Thank you for your feedback, I also use this method currently and I take screenshots over the hours/days that pass. We are uninstalling an application worldwide, on more than 18,000 devices, so my wish was to have something more industrialized and finer.
