Retrieve members of static, smart computer groups and members of reports
  • July 19, 2024
  • 4 replies
  • 181 views
HI
I apologize in advance if that question was asked but I cannot find answers :(
I need to retrieve following information through API:
1. retrieve members through API from static computer groups - i need to list computer names that belong to specific computer groups.  All i'm able to find is how to list computer groups, but not how to retrieve members.
# Endpoint to retrieve computer groups
$computerGroupsUrl = "$jamfUrl/api/v1/computer-groups"
# Request computer groups
$responseComputerGroups = Invoke-RestMethod -Uri $computerGroupsUrl -Method Get -Headers $headers -ErrorAction Stop
2. retrieve members through API from smart computer groups - i need to list computer names that belong to specific computer groups
3. retrieve data through API from "reports" found under "Search inventory"
  • July 22, 2024
Do you already know the static groups you need the members of? Or do you need to read ALL computer groups, determine which ones are static, then output the members of all of them? Or do you have like 8 static groups and you just want an API script that will list the members?
Tangentism
  • July 30, 2024
If its just 1 group then you can do the following. You will need to install JQ (https://jqlang.github.io/jq/download/) as I use this to easily manipulate JSON datasets I get back from the API
If you use this in Jamf, you need to set up an API client &  roles then add the following script parameters:
4: Jamf URL
5: Client ID
6: Client Secret
7: Device group ID
If you want to enter more than one group then adapt how it reads parameter 7 and add it to an array instead a variable then loop through it to get each group and assign the results to a new array.
#!/usr/bin/env zsh # ----------------------------------------------------------------------------- # PREREQUISITES # ----------------------------------------------------------------------------- # Get the logged in user ConsoleUser=$(echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }') # Log Path log_path="/Users/${ConsoleUser}/Library/Logs/ComputerGroupReport.log" # Create log file if it doesnt exist [[ ! -f "${log_path}" ]] && touch "${log_path}" # Set up logging log_message() { echo "$(date '+%F %X'): $1" | tee -a "$log_path" } # ----------------------------------------------------------------------------- # SCRIPT PARAMETERS # ----------------------------------------------------------------------------- # JAMF Cloud details jamf_url="${4:-}" # API login details client_id="${5:-}" client_secret="${6:-}" # Computer group ID device_group="${7:-}" [[ "$device_group" == "" ]] && log_message "No group provided. Exiting."; exit 1 || log_message "Group provided: $device_group" # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # FUNCTIONS # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # ----------------------------------------------------------------------------- # API AUTHENTICATION # ----------------------------------------------------------------------------- # Establish API token. API session is set in API client and roles section get_access_token() { response=$(/usr/bin/curl \\ --silent \\ --location \\ --request POST "${jamf_url}/api/oauth/token" \\ --header "Content-Type: application/x-www-form-urlencoded" \\ --data-urlencode "client_id=${client_id}" \\ --data-urlencode "grant_type=client_credentials" \\ --data-urlencode "client_secret=${client_secret}") current_epoch=$(date +%s) access_token=$(echo "$response" | plutil -extract access_token raw -) token_expires_in=$(echo "$response" | plutil -extract expires_in raw -) token_expiration_epoch=$((+-1)) } check_token_expiration() { current_epoch=$(date +%s) if [[ $token_expiration_epoch -ge $current_epoch ]]; then echo "Current epoch time: $current_epoch" echo "Token valid until the following epoch time: " "$token_expiration_epoch" else echo "No valid token available, getting new token" get_access_token fi } invalidate_token() { responseCode=$(/usr/bin/curl \\ -w "%{http_code}" \\ -H "Authorization: Bearer ${access_token}" $jamf_url/api/v1/auth/invalidate-token \\ -X POST \\ -s -o /dev/null) if [[ ${responseCode} == 204 ]]; then echo "Token successfully invalidated" access_token="" token_expiration_epoch="0" elif [[ ${responseCode} == 401 ]]; then echo "Token already invalid" else echo "An unknown error occurred invalidating the token" fi } # ----------------------------------------------------------------------------- # FUNCTIONS: API CALLS # ----------------------------------------------------------------------------- # Gets membership of computer group get_device_group() { recovery_devices=$(/usr/bin/curl \\ --silent \\ --request GET \\ --header "Authorization: Bearer ${access_token}" \\ --header "Accept: application/json" \\ --url "${jamf_url}/JSSResource/computergroups/id/$device_group") } # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # OPERATIONS # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # Create an API token get_access_token # Read the computer group for computer IDs get_device_group "$device_group" ### Display the raw data back from the API echo $recovery_devices | jq -r . ### List only the computer names echo "$recovery_devices" | jq -r '.[].computers[].name'
howie_isaacks
Forum|alt.badge.img+23
  • December 23, 2025
Here is a script I wrote for this. It uses the same API command as the one posted above. Near the bottom you can specify if you want the output to be written to a CSV. You can also change the file type to TXT.
#!/bin/zsh --no-rcs
:<<ABOUT_THIS_SCRIPT
Outputs the membership of the group specified in the "group_id" variable.
Output is computer serials
USAGE:
Option 1: Activate line 29. Deactivate lines 32-34
Enter a group ID (smart or static) into the variable "group_id".
Option 2: Activate lines 32-34. Deactivate line 29. Respond to prompt for group ID.
Use line 89 to specify if you want the group membership to be output to CSV.
12/23/2025 | Howie Canterbury
ABOUT_THIS_SCRIPT
# Specify group ID by either filling it into #
# the value for "group_id" or when prompted. #
# Activate the appropriate lines below. #
# Option 1
#group_id=""
# Option 2
echo "Enter group ID to check its membership."
printf "Group ID:"
read group_id
echo "Checking group ID ${group_id}"
# JAMF PRO API LOGIN #
url="YOUR_SERVER"
client_id="JAMF_PRO_API_CLIENT_ID"
client_secret="CLIENT_SECRET"
verify="" # Specify "yes" if you want your bearer token to be output to verify login info
# Jamf API authentication function
jamfAPI_auth() {
response=$(curl --silent --location --request POST "${url}/api/oauth/token" \
token_expiration_epoch=$(($current_epoch + $token_expires_in - 1))
# Start authenticated API session
jamfAPI_auth
# VALIDATE API LOGIN #
# The token and expiration time will be echoed into the script output #
# to verify that the API login credentials provided are working. #
if [[ "$verify" == "yes" ]]; then
echo "API token: ${token}"
echo "Token expires in: ${token_expires_in} seconds"
# OUTPUT LIST OF COMPUTERS IN SPECIFIED GROUP #
# Check and report group membership. Output list of computer serial numbers.
check_group_members=$(
/usr/bin/curl --request GET \
--header "Authorization: Bearer ${token}" \
--url "${url}/JSSResource/computergroups/id/${group_id}"
# Output list of computers (serial numbers) that are members of the group
group_membership=$(echo "$check_group_members" | jq -r '.computer_group.computers[].serial_number' )
echo $group_membership
# Output to CSV?
output_to_csv="y" # Enter "y" if output to CSV is needed
if [[ "$output_to_csv" == "y" ]]; then
currentUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }')
for serial in "${group_membership[@]}"; do
echo "${serial}" >> "/Users/${currentUser}/Desktop/Group_${group_id}_members.csv"
done
mattjerome
  • December 24, 2025
You can also go at it the reverse way. Comb through computers and if the computer is in that group and a the username matches what you want, add it to a list. That’s what I’d do. It’s far less complicated. If you can do python, it’ll be easier with that
Here’s a basic outline:
  1. Have a CSV of the usernames you need
  2. Have a script read the csv
  3. Call all computers with the group memberships
  4. if the username is in the list and the group you want is in computer groups, grab the data you want
  5. output to a csv or other desired destination.
