Can support EA for this script
  • August 7, 2024
  • 5 replies
  • 100 views
Dear Team,
I have a script to obtain all browsers extensions (Safari, Edge, Chrome and Firefox) the script is running well and I would like to use it as EA. Can any body give a hand? Thanks
Here is the output
[Warn] This script may not be able to access all user directories unless run as root. Safari Extensions: User: xxx, Name: com.adguard.safari.AdGuard.Extension, Id: TC3Q7MAJXF Chrome Extensions: User: xxx, Profile Name: Person 1, Name: Google Docs Offline, Id: ghbmnnjooekpmoecnnnilnnbdlolhkhi, Version: 1.78.1 Firefox Addons: User: xxx, Profile Name: default-release, Name: AdGuard AdBlocker, Id: adguardadblocker@adguard.com, Description: Unmatched adblock extension against advertising and pop-ups. Blocks ads on Facebook, Youtube and all other websites.
Here is the scripts
#!/usr/bin/env bash _arg_multilineField=$1 _arg_wysiwygField=$2 # Determines whether or not help text is necessary and routes the output to stderr die() { local _ret="${2:-1}" echo "$1" >&2 test "${_PRINT_HELP:-no}" = yes && print_help >&2 exit "${_ret}" } # Prints the help text print_help() { echo "Get the browser extensions for Safari, Chrome, Firefox, and Edge that are installed on a macOS system." echo "Usage: [multilineCustomFieldName] [wysiwygCustomFieldName]" } # Check if --help or -h is passed as an argument for _arg in "$@"; do case "$_arg" in --help | -h) print_help exit 0 ;; esac done # Warn that if not running as root, the script may not be able to access all user directories if [[ $EUID -ne 0 ]]; then echo "[Warn] This script may not be able to access all user directories unless run as root." fi # Converts a string input into an HTML table format convertToHTMLTable() { local _arg_delimiter=" " local _arg_inputObject # Process command-line arguments for the function while test $# -gt 0; do _key="$1" case "$_key" in --delimiter | -d) test $# -lt 2 && echo "[Error] Missing value for the optional argument" >&2 && return 1 _arg_delimiter=$2 shift ;; --*) echo "[Error] Got an unexpected argument" >&2 return 1 ;; *) _arg_inputObject=$1 ;; esac shift done # Handles missing input by checking stdin or returning an error if [[ -z $_arg_inputObject ]]; then if [ -p /dev/stdin ]; then _arg_inputObject=$(cat) else echo "[Error] Missing input object to convert to table" >&2 return 1 fi fi local htmlTable="<table>\\n" htmlTable+=$(printf '%b' "$_arg_inputObject" | head -n1 | awk -F "$_arg_delimiter" '{ printf "<tr>" for (i=1; i<=NF; i+=1) { printf "<th>"$i"</th>" } printf "</tr>" }') htmlTable+="\\n" htmlTable+=$(printf '%b' "$_arg_inputObject" | tail -n +2 | awk -F "$_arg_delimiter" '{ printf "<tr>" for (i=1; i<=NF; i+=1) { printf "<td>"$i"</td>" } print "</tr>" }') htmlTable+="\\n</table>" printf '%b' "$htmlTable" '\\n' } createExtList() { userHome=$1 browser=$2 # chrome or edge user_name=$(echo "$userHome" | cut -d "/" -f 3) if [[ "${browser}" == "chrome" ]]; then manifests=$(find "${userHome}/Library/Application Support/Google/Chrome" -type f -name 'manifest.json' 2>/dev/null | grep "Extensions") profileLocalState="${userHome}/Library/Application Support/Google/Chrome/Local State" elif [[ "${browser}" == "edge" ]]; then manifests=$(find "${userHome}/Library/Application Support/Microsoft Edge" -type f -name 'manifest.json' 2>/dev/null | grep "Extensions") profileLocalState="${userHome}/Library/Application Support/Microsoft Edge/Local State" fi en_messages="_locales/en/messages.json" enUS_messages="_locales/en_US/messages.json" while IFS= read -r manifest; do # Check if we can read the manifest file if [ ! -f "$manifest" ]; then continue fi profileName=$( # Get profile name from profileLocalState that contains json data # "profile.info_cache.Default" is the default profile osascript -l JavaScript -e " var profileLocalState = JSON.parse(ObjC.unwrap($.NSString.alloc.initWithDataEncoding($.NSData.dataWithContentsOfFile('$profileLocalState'), $.NSUTF8StringEncoding))); // Get each profile name based on the profile path if ('$browser' === 'chrome') { var profilePathName = '$manifest'.split('/')[7]; } else if ('$browser' === 'edge') { var profilePathName = '$manifest'.split('/')[6]; } for (var key in profileLocalState.profile.info_cache) { if (key.toLowerCase() === profilePathName.toLowerCase()) { var profileName = profileLocalState.profile.info_cache[key].name; break; } } profileName; " ) # Get the id of the extension from the manifest path by splitting the path on '/' and getting the 9th element if [[ "${browser}" == "chrome" ]]; then extID=$(awk -F '/' '{print $10}' <<<"$manifest") elif [[ "${browser}" == "edge" ]]; then extID=$(awk -F '/' '{print $9}' <<<"$manifest") fi # Get name from manifest name=$( osascript -l JavaScript -e " var data = JSON.parse(ObjC.unwrap($.NSString.alloc.initWithDataEncoding($.NSData.dataWithContentsOfFile('$manifest'), $.NSUTF8StringEncoding))); var name = data.name; name; " ) # Get version from manifest version=$( osascript -l JavaScript -e " var data = JSON.parse(ObjC.unwrap($.NSString.alloc.initWithDataEncoding($.NSData.dataWithContentsOfFile('$manifest'), $.NSUTF8StringEncoding))); var version = data.version; version; " ) # Get the name of the extension from the messages.json file if the name contains "__MSG_" if [[ "${name}" =~ "__MSG_" ]]; then name=$(echo "$name" | sed 's/__MSG_//g' | sed 's/__$//g') if [ -f "$(dirname "$manifest")/$en_messages" ]; then # Check if message.json exists in en folder name=$( osascript -l JavaScript -e " var data = JSON.parse(ObjC.unwrap($.NSString.alloc.initWithDataEncoding($.NSData.dataWithContentsOfFile('$(dirname "$manifest")/$en_messages'), $.NSUTF8StringEncoding))); var searchKey = '$name'; var asLowercase = searchKey.toLowerCase(); var name = data[Object.keys(data).find(key => key.toLowerCase() === asLowercase)].message; name; " 2>/dev/null ) elif [ -f "$(dirname "$manifest")/$enUS_messages" ]; then # Check if message.json exists in enUS folder name=$( osascript -l JavaScript -e " var data = JSON.parse(ObjC.unwrap($.NSString.alloc.initWithDataEncoding($.NSData.dataWithContentsOfFile('$(dirname "$manifest")/$enUS_messages'), $.NSUTF8StringEncoding))); var searchKey = '$name'; var asLowercase = searchKey.toLowerCase(); var name = data[Object.keys(data).find(key => key.toLowerCase() === asLowercase)].message; name; " 2>/dev/null ) fi fi if [[ -n "$name" ]]; then printf "%s|%s|%s|%s|%s\\n" "$user_name" "$profileName" "$name" "$extID" "$version" else printf "%s|%s|%s|%s|%s\\n" "$user_name" "$profileName" "Name Not Found" "$extID" "$version" fi done <<<"$manifests" } # Get a list of all users in the /Users directory except Shared users=() for user in /Users/*; do if [[ -d "$user" && ! "$user" =~ /Users/Shared ]]; then users+=("${user##*/}") fi done # Error when no users are found if [[ ${#users[@]} -eq 0 ]]; then _PRINT_HELP=no die "[Error] No user directories found in /Users" fi safari_title="Safari Extensions" safari_extensions="" chrome_title="Chrome Extensions" chrome_extensions="" firefox_title="Firefox Addons" firefox_addons="" edge_title="Edge Extensions" edge_extensions="" # Safari for user in "${users[@]}"; do ext_plist="/Users/$user/Library/Containers/com.apple.Safari/Data/Library/Safari/AppExtensions/Extensions.plist" pattern='(com\\..*)\\s\\((.*)\\)' if [[ -f "$ext_plist" ]]; then safari_extensions+=$'\\n'"$( grep -Eo "$pattern" "$ext_plist" | while read -r line; do ext_name=$(echo "$line" | awk -F ' ' '{print $1}') ext_id=$(echo "$line" | awk -F ' ' '{print $2}' | tr -d '()') printf "%s|%s|%s\\n" "$user" "$ext_name" "$ext_id" done )" fi done # Chrome for user in "${users[@]}"; do # Add a newline to the beginning of the string to separate the results from the previous user chrome_extensions+=$'\\n'"$(createExtList "/Users/$user" "chrome")" done # Firefox Get installed Addons (not extensions) firefox_addons=$( # Loop through each user profile for user in "${users[@]}"; do firefox_path="/Users/$user/Library/Application Support/Firefox" profile_dir="$firefox_path/Profiles" # Check if Profiles directory exists if [[ -d "$profile_dir" ]]; then profiles_ini_path="$firefox_path/profiles.ini" # Check if profiles.ini file exists if [[ -f "$profiles_ini_path" ]]; then profiles_ini=$(cat "$profiles_ini_path") # Parse the profiles.ini file and get the profile names and paths # Get each section awk -F '=' '/\\[/{print $1}' <<<"$profiles_ini" | while read -r section; do # Get the profile name profile_name=$( awk -F'=' -v section="$section" -v k="Name" ' $0==section{ f=1; next } /\\[/{ f=0; next } f && $1==k{ print $0 } ' <<<"$profiles_ini" | sed 's/^Name=//' ) # Get the profile path profile_path=$( awk -F'=' -v section="$section" -v k="Path" ' $0==section{ f=1; next } /\\[/{ f=0; next } f && $1==k{ print $0 } ' <<<"$profiles_ini" | sed 's/^Path=//' ) # Get the addons json file path ext_dir="$firefox_path/$profile_path/addons.json" if [[ -f "$ext_dir" ]]; then # Get name, id, and description from the addons.json file ff_results=$( osascript -l JavaScript -e " var data = JSON.parse(ObjC.unwrap($.NSString.alloc.initWithDataEncoding($.NSData.dataWithContentsOfFile('$ext_dir'), $.NSUTF8StringEncoding))); var addons = data.addons; var result = ''; for (var i = 0; i < addons.length; i++) { var addon = addons[i]; result += addon.name + ',' + addon.id + ',' + addon.description + '\\n'; } result; " ) Old_IFS=$IFS echo "$ff_results" | while IFS=, read -r name id description; do printf "%s|%s|%s|%s|%s\\n" "$user" "$profile_name" "$name" "$id" "$description" done IFS=$Old_IFS fi done fi fi done ) # Edge for user in "${users[@]}"; do # Add a newline to the beginning of the string to separate the results from the previous user edge_extensions+=$'\\n'"$(createExtList "/Users/$user" "edge")" done if [[ -n $_arg_multilineField ]] || [[ -n $_arg_wysiwygField ]]; then # Add headers if a custom field is set if [[ -n "${safari_extensions}" ]]; then safari_extensions=$(echo -e "User|Name|Id\\n$safari_extensions") fi if [[ -n "${chrome_extensions}" ]]; then chrome_extensions=$(echo -e "User|Profile Name|Name|Id|Version\\n$chrome_extensions") fi if [[ -n "${firefox_addons}" ]]; then firefox_addons=$(echo -e "User|Profile Name|Name|Id|Description\\n$firefox_addons") fi if [[ -n "${edge_extensions}" ]]; then edge_extensions=$(echo -e "User|Profile Name|Name|Id|Version\\n$edge_extensions") fi fi # Formats the extension data for the multiline custom field multilineValue="" # Check if any browser extensions were found if [[ -n "$safari_title" ]] && [[ -n "${safari_extensions}" ]]; then multilineValue+=$'\\n' multilineValue+="$safari_title:" multilineValue+=$'\\n' multilineValue+=$( # Convert the safari_extensions string to a table format. Skip the first line as it is the header echo "$safari_extensions" | tail -n +2 | while IFS='|' read -r user name id; do printf "User: %s, Name: %s, Id: %s\\n" "$user" "$name" "$id" done ) fi if [[ -n "$chrome_title" ]] && [[ -n "${chrome_extensions}" ]]; then multilineValue+=$'\\n' multilineValue+="$chrome_title:" multilineValue+=$'\\n' multilineValue+=$( # Convert the chrome_extensions string to a table format. Skip the first line as it is the header echo "$chrome_extensions" | tail -n +2 | while IFS='|' read -r user_name profileName name id version; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Version: %s\\n" "$user_name" "$profileName" "$name" "$id" "$version" fi done ) fi if [[ -n "$firefox_title" ]] && [[ -n "${firefox_addons}" ]]; then multilineValue+=$'\\n' multilineValue+="$firefox_title:" multilineValue+=$'\\n' multilineValue+=$( # Convert the firefox_addons string to a table format. Skip the first line as it is the header echo "$firefox_addons" | tail -n +2 | while IFS='|' read -r user profileName name id description; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Description: %s\\n" "$user" "$profileName" "$name" "$id" "$description" fi done ) fi if [[ -n "$edge_title" ]] && [[ -n "${edge_extensions}" ]]; then multilineValue+=$'\\n' multilineValue+="$edge_title:" multilineValue+=$'\\n' multilineValue+=$( # Convert the edge_extensions string to a table format. Skip the first line as it is the header echo "$edge_extensions" | tail -n +2 | while IFS='|' read -r user_name profileName name id version; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Version: %s\\n" "$user_name" "$profileName" "$name" "$id" "$version" fi done ) fi # if all multilineValue is empty, set it to "No browser extensions found" if [[ -z "$multilineValue" ]]; then multilineValue="No browser extensions found" fi # Tries to set the multiline custom field using ninjarmm-cli and captures the output if ! output=$(printf '%b' "$multilineValue" set --stdin "$_arg_multilineField" 2>&1); then echo "[Error] $output" >&2 EXITCODE=1 fi # Checks if there is a WYSIWYG custom field set if [[ -n $_arg_wysiwygField ]]; then echo "" # Initializes an HTML formatted string with headers and extension details # Check if any browser extensions were found if [[ -n "$safari_title" ]] && [[ -n "${safari_extensions}" ]]; then htmlObject+="<h2>$safari_title</h2>" htmlObject+=$(echo "$safari_extensions" | convertToHTMLTable --delimiter '|') fi if [[ -n "$chrome_title" ]] && [[ -n "${chrome_extensions}" ]]; then htmlObject+="<h2>$chrome_title</h2>" htmlObject+=$(echo "$chrome_extensions" | convertToHTMLTable --delimiter '|') fi if [[ -n "$firefox_title" ]] && [[ -n "${firefox_addons}" ]]; then htmlObject+="<h2>$firefox_title</h2>" htmlObject+=$(echo "$firefox_addons" | convertToHTMLTable --delimiter '|') fi if [[ -n "$edge_title" ]] && [[ -n "${edge_extensions}" ]]; then htmlObject+="<h2>$edge_title</h2>" htmlObject+=$(echo "$edge_extensions" | convertToHTMLTable --delimiter '|') fi # if all htmlObject is empty, set it to "No browser extensions found" if [[ -z "$htmlObject" ]]; then htmlObject="<p>No browser extensions found</p>" fi # Replace <table> with <table style='white-space:nowrap;'> htmlObject=${htmlObject//<table>/<table style=\\'white-space:nowrap;\\'>} # Tries to set the WYSIWYG custom field using ninjarmm-cli and captures the output if ! output=$(printf '%b' "$htmlObject" | set --stdin "$_arg_wysiwygField" 2>&1); then EXITCODE=1 fi fi # If both _arg_multilineField and _arg_wysiwygField are not set, or if there is an error saving to the custom fields, print the results if [[ -z $_arg_multilineField && -z $_arg_wysiwygField ]] || [[ $EXITCODE -ne 0 ]]; then echo "" echo "$safari_title:" echo "$safari_extensions" | while IFS='|' read -r user name id; do if [[ -n "$name" ]]; then printf "User: %s, Name: %s, Id: %s\\n" "$user" "$name" "$id" fi done echo "" echo "$chrome_title:" echo "$chrome_extensions" | while IFS='|' read -r user profileName name id version; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Version: %s\\n" "$user" "$profileName" "$name" "$id" "$version" fi done echo "" echo "$firefox_title:" echo "$firefox_addons" | while IFS='|' read -r user profileName name id description; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Description: %s\\n" "$user" "$profileName" "$name" "$id" "$description" fi done echo "" echo "$edge_title:" echo "$edge_extensions" | while IFS='|' read -r user profileName name id version; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Version: %s\\n" "$user" "$profileName" "$name" "$id" "$version" fi done # If no extensions are found, print a message if [[ -z "$safari_extensions" ]] && [[ -z "$chrome_extensions" ]] && [[ -z "$firefox_addons" ]] && [[ -z "$edge_extensions" ]]; then echo "[Info] No Browser Extensions Found" fi fi
Best answer by stevewood
It should be as simple as adding <result></result> to the if/then statement that echos output if _arg_multilineField and _arg_wysiwygField are not set. In my IDE I set line 415 to
echo "<result>"
and line 443 to:
echo "</result>"
So the last 35 or so lines of the script look like this:
# If both _arg_multilineField and _arg_wysiwygField are not set, or if there is an error saving to the custom fields, print the results if [[ -z $_arg_multilineField && -z $_arg_wysiwygField ]] || [[ $EXITCODE -ne 0 ]]; then echo "<result>" echo "$safari_title:" echo "$safari_extensions" | while IFS='|' read -r user name id; do if [[ -n "$name" ]]; then printf "User: %s, Name: %s, Id: %s\\n" "$user" "$name" "$id" fi done echo "" echo "$chrome_title:" echo "$chrome_extensions" | while IFS='|' read -r user profileName name id version; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Version: %s\\n" "$user" "$profileName" "$name" "$id" "$version" fi done echo "" echo "$firefox_title:" echo "$firefox_addons" | while IFS='|' read -r user profileName name id description; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Description: %s\\n" "$user" "$profileName" "$name" "$id" "$description" fi done echo "" echo "$edge_title:" echo "$edge_extensions" | while IFS='|' read -r user profileName name id version; do if [[ -n "$name" ]]; then printf "User: %s, Profile Name: %s, Name: %s, Id: %s, Version: %s\\n" "$user" "$profileName" "$name" "$id" "$version" fi done echo "</result>" # If no extensions are found, print a message if [[ -z "$safari_extensions" ]] && [[ -z "$chrome_extensions" ]] && [[ -z "$firefox_addons" ]] && [[ -z "$edge_extensions" ]]; then echo "<result>[Info] No Browser Extensions Found</result>" fi fi
That seemed to work in my very limited testing, and produced an EA that looked like this on a machine that only has extensions in Edge:
stevewood
Forum|alt.badge.img+38
  • August 7, 2024
echo "<result>"
and line 443 to:
echo "</result>"
husnudagidir
  • September 22, 2024
Hi Everyone,
The script worked for me and reflected its output in the Details section under Logs. However, I did not understand how to export this data. Do you have any comments on this?
stevewood
  • September 23, 2024
Hi Everyone,
If you need to export the data you can use an Advanced Search. Select the checkbox on the Extension Attributes tab for the EA that you want to export. Then use the Report tab to export a CSV or schedule the sending of the report.
https://learn.jamf.com/en-US/bundle/jamf-pro-documentation-current/page/Advanced_Computer_Searches.html
husnudagidir
  • October 23, 2024
Thank you @stevewood
shrisivakumaran
This scripts returns old Safari Extension details which removed already and not printing the current Safari Extension which is installed on the device.
Also capturing and returns multiple entry for same extensions with different versions
