Extension attribute for Microsoft Office 2021
  • August 8, 2024
  • 4 replies
  • 67 views
I had this extension attribute that will tell me if the mac had Office 2016 or 2019 installed, I need one now for office 2021, can anyone help me modify it?
wordVersion=$(defaults read "/Applications/Microsoft Word.app/Contents/Info.plist" CFBundleShortVersionString)
majorVersion=$(awk -F '.' '{print $1}' <<< "$wordVersion")
minorVersion=$(awk -F '.' '{print $2}' <<< "$wordVersion")
if [[ $majorVersion -ge "15" ]]; then
if [[ "$majorVersion" -ge "16" ]] && [[ "$minorVersion" -ge "17" ]]; then
echo "<result>2019</result>"
echo "<result>2016</result>"
if [[ -d "/Applications/Microsoft Office 2011/" ]]; then
echo "<result>2011</result>"
echo "<result>Not Installed</result>"
Best answer by jamf-42
maybe im missing the question,
add a patch management for each of the Office apps..
then you get version tracked..
jamf-42
  • August 8, 2024
  • August 12, 2024
Thanks for the suggestion, I was able to create a smart group based on the patch management info.
dlondon
  • August 14, 2024
Hi @ucdcastillo I use a script by @pbowden which you can find here https://github.com/pbowden-msft/ExtensionAttributes. It's called Office_License.sh
kwoodard
  • September 16, 2024
I'm actually trying to do this now. Do we have to provide the packages for each individual Office app, or is there some way to use the Jamf repository? If I can use the Jamf, how do I set that up? I'm slamming my head into a wall to do this.
