Delay time after POST or DELETE api calls
  • August 21, 2024
  • 40 views
Hello community.
When I create or delete something on my Jamf site through api call (for example, creating a new policy with  POST on "/JSSResource/policies/id/-1"), I am getting a successful response with code 200 and the newly created policy's id.
Then, I am trying to fetch all policies from my Jamf site (GET on "
/JSSResource/policies"), but the response does not contain the newly created policy.
Should I wait for few seconds before I fetch my policies and check if the creation succeeded? (Since I am running a code that does it I need to know how much sleep time I should add). Are there a different solution than doing busy waiting?
All I wrote I experience for DELETE requests as well.
Thanks in advance
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • August 21, 2024
If you're using Jamf Cloud, it has multiple servers. You're likely changing one and the other hasn't synchronized yet. Usually takes a minute or less.
  • August 25, 2024
@talkingmoose Thanks.
Is there a query I can do to know when the servers are synced?
Is there a way to know if a set of API calls are going to be resolved on different server?
talkingmoose
  • Community Manager
  • August 26, 2024
There's no way to tell other than to refresh the page.
It's usually less than a minute. You could build in a sleep command to wait, if it's becoming a problem for you.
