Self Service Script to transfer Static Groups from old to new Mac
  • August 22, 2024
  • 0 replies
  • 20 views
Hey Guys,
no real Question but i saw some similar posts and questions or request for something like "$sbuject_title" ..
I want to share my solution for this scenario and perhaps some of you has an idea to optimize it:
User got new mac and wants to transfer all Static Groups from the old to the new mac.
I provide this script as policy in Self Service:
#!/bin/zsh #region - Prerequisites ################################################################################################################################################################################################ ## Create tmp location # Define the path for the temporary folder TMP_DIR="/Users/Shared/tmp" # Check if the folder already exists if [ -d "$TMP_DIR" ]; then echo "The folder $TMP_DIR already exists." else # Create the folder mkdir -p "$TMP_DIR" # Check if the creation was successful if [ $? -eq 0 ]; then echo "The temporary folder has been successfully created at $TMP_DIR." # Set permissions (optional) chmod 755 "$TMP_DIR" echo "Permissions have been set to 755." else echo "Error: The folder could not be created." exit 1 fi fi # Variable for tmp files txt_tmp=/Users/Shared/tmp/inventory_details.txt txt_tmp2=/Users/Shared/tmp/static_groups.txt GROUP_ID_FILE=/Users/Shared/tmp/static_groups_ID.txt # API login bearerToken="" url=<X> client_id="X" client_secret="X" # Create Token token=$(curl --location --request POST "$url/api/oauth/token" \\ --header "Content-Type: application/x-www-form-urlencoded" \\ --data-urlencode "client_id=$client_id" \\ --data-urlencode "grant_type=client_credentials" \\ --data-urlencode "client_name=Test" \\ --data-urlencode "client_secret=$client_secret") # Catch Token bearerToken=$(echo "$token" | plutil -extract access_token raw -) #endregion################################################################################################################################################################################################ #region - Getting Static Groups from old MacBook ################################################################################################################################################################################################ # Get the serial number using Dialog read -r -d '' applescriptCode <<'EOF' set dialogText to text returned of (display dialog "Bitte trage die alte MacBook-Seriennummer ein." default answer "no input") return dialogText EOF serial_number=$(osascript -e "$applescriptCode"); # Prepend "MC-" to the serial number computerName="MC-$serial_number" # Get Jamf Computer ID from Serial Number deviceID=$(curl -s -H "Accept: text/xml" -H "Authorization: Bearer ${bearerToken}" ${url}/JSSResource/computers/name/"$computerName" | xmllint --xpath '/computer/general/id/text()' -) # Inventory Collection from Computer inventory_details=$(curl -s -H "Accept: application/json" -H "Authorization: Bearer ${bearerToken}" "${url}/api/v1/computers-inventory-detail/$deviceID" -X GET) echo "$inventory_details" >> $txt_tmp # Use grep to delete everything except 2 Lines with: "smartGroup" : false grep -B 2 '"smartGroup" : false' $txt_tmp > $txt_tmp2 # cutting only Group IDs and writing into txt file awk -F'"' '/"groupId" :/ {print $4}' $txt_tmp2 > $GROUP_ID_FILE #endregion################################################################################################################################################################################################ #region - Put new MacBook into Static Groups ################################################################################################################################################################################################ ## Function to add computer to a static group add_to_group() { xml_data="<computer_group> <id>$group_id</id> <computer_additions> <computer> <id>$computer_id</id> </computer> </computer_additions> </computer_group>" response=$(curl -s -w "%{http_code}" -o /dev/null \\ -X PUT \\ -H "Authorization: Bearer $bearerToken" \\ -H "Content-Type: application/xml" \\ -d "$xml_data" \\ "$url/JSSResource/computergroups/id/$group_id") if [ "$response" = "201" ]; then echo "Successfully added computer $computer_id to group $group_id" else echo "Failed to add computer $computer_id to group $group_id. HTTP response: $response" fi } ## Details new MacBook # Get new MacBook-Name read -r -d '' applescriptCode <<'EOF' set dialogText to text returned of (display dialog "Bitte trage die neue MacBook-Seriennummer ein." default answer "no input") return dialogText EOF serialNumber_new=$(osascript -e "$applescriptCode"); computerName_new="MC-$serialNumber_new" # Get Jamf Computer ID from Serial Number computer_id=$(curl -s -H "Accept: text/xml" -H "Authorization: Bearer ${bearerToken}" ${url}/JSSResource/computers/name/"$computerName_new" | xmllint --xpath '/computer/general/id/text()' -) # Check if the group ID file exists if [ ! -f "$GROUP_ID_FILE" ]; then echo "Error: Group ID file not found at $GROUP_ID_FILE" exit 1 fi # Read group IDs from the file and add computer to each group while IFS= read -r group_id || [[ -n "$group_id" ]]; do # Trim whitespace group_id=$(echo "$group_id" | tr -d '[:space:]') if [[ -n "$group_id" ]]; then echo "Adding computer $computer_id to group $group_id" add_to_group "$computer_id" "$group_id" fi done < "$GROUP_ID_FILE" echo "Software Gruppen wurden auf neuem MacBook $computerName_new übertragen" #endregion################################################################################################################################################################################################ #region - cleanup tmp files and folder ################################################################################################################################################################################################ # rm $txt_tmp # rm $txt_tmp2 # rm /Users/Shared/tmp #endregion################################################################################################################################################################################################
Next Step is build a lovely Swift Dialog UI to glow it up!
If you have some Input feel free to share it!
