I have always used JSSConduit to purge old classes to learn JAMF no longer accepts basic authentication. Support sends me the below script to run without explanation. I am a network guy who also manages Jamf, and par for the course Jamf Support falls short. As I stated, I am not a JAMF scripting expert so I am only looking for a detailed procedure on how to delete the classes which typically took me 5 minutes has now lingered for 3 weeks. Any expert advice / instructions would be appreciated. Script below:
#!/bin/bash #################################################################################################### # # THIS SCRIPT IS NOT AN OFFICIAL PRODUCT OF JAMF # AS SUCH IT IS PROVIDED WITHOUT WARRANTY OR SUPPORT # # BY USING THIS SCRIPT, YOU AGREE THAT JAMF # IS UNDER NO OBLIGATION TO SUPPORT, DEBUG, OR OTHERWISE # MAINTAIN THIS SCRIPT # #################################################################################################### # # DESCRIPTION # This is a self destruct script that will delete all classes in Jamf Pro. # Requires a user that has READ and DELETE privys for Classes. # The noRefesh version goes through 100 at a time before forcing a class refresh with Jamf. # This allows the script to run much faster than past scripts. # Jul 22, 2024 - version 3.0 # updated to accomidate a change that was made to curl # added an extra step at the end to create a class and delete it. This forces the class refresh. # #################################################################################################### # Variable declarations bearerToken="" tokenExpirationEpoch="0" count=0 re='^[0-9]+$' # Set the Jamf Pro URL here if you want it hardcoded. jamfpro_url="" # Set the username here if you want it hardcoded. jamfpro_user="" # Set the password here if you want it hardcoded. jamfpro_password="" # Function to gather and format bearer token getBearerToken() { response=$(/usr/bin/curl -k -k -s -u "$jamfpro_user":"$jamfpro_password" "$jamfpro_url"/api/v1/auth/token -X POST) bearerToken=$(echo "$response" | plutil -extract token raw -) tokenExpiration=$(echo "$response" | plutil -extract expires raw - | awk -F . '{print $1}') tokenExpirationEpoch=$(date -j -f "%Y-%m-%dT%T" "$tokenExpiration" +"%s") echo "New bearer token generated." echo "Token valid until the following date/time UTC: " "$tokenExpiration" } # Function to check token expiration checkTokenExpiration() { nowEpochUTC=$(date -j -f "%Y-%m-%dT%T" "$(date -u +"%Y-%m-%dT%T")" +"%s") if [[ tokenExpirationEpoch -lt nowEpochUTC ]] then echo "No valid token available, getting new token" getBearerToken fi } # Funtion to invalidate token invalidateToken() { responseCode=$(/usr/bin/curl -k -w "%{http_code}" -H "Authorization: Bearer ${bearerToken}" $jamfpro_url/api/v1/auth/invalidate-token -X POST -s -o /dev/null) if [[ ${responseCode} == 204 ]] then echo "Bearer token successfully invalidated" bearerToken="" tokenExpirationEpoch="0" elif [[ ${responseCode} == 401 ]] then echo "Bearer token already invalid" else echo "An unknown error occurred invalidating the bearer token" fi } # Dispaly warning and confrim user would like to continue echo "#####################" echo "###!!! WARNING !!!###" echo "#####################" echo "This is a self destruct script that will delete all classes." echo "There is no undo button." while true; do read -p "Are you sure you want to continue? [ y | n ] " answer case $answer in [Yy]* ) break;; [Nn]* ) exit;; * ) echo "Please answer y | n";; esac done # If the Jamf Pro URL, the account username and/or the account password have not been provided, # the below will prompt the user to enter the necessary information. if [[ -z "$jamfpro_url" ]]; then read -p "Please enter your Jamf Pro server URL : " jamfpro_url fi if [[ -z "$jamfpro_user" ]]; then read -p "Please enter your Jamf Pro user account : " jamfpro_user fi if [[ -z "$jamfpro_password" ]]; then read -p "Please enter the password for the $jamfpro_user account: " -s jamfpro_password fi # Remove the trailing slash from the Jamf Pro URL if needed. jamfpro_url=${jamfpro_url%%/} echo echo "Credentials received" echo # Genrating bearer token echo "Generating bearer token for server authentication..." getBearerToken echo echo "Deleting all classes now!" # create array with all class IDs classID=$(/usr/bin/curl -k --silent --header "Authorization: Bearer ${bearerToken}" --header "accept: text/xml" ${jamfpro_url}/JSSResource/classes | xmllint --format - | awk -F '[<>]' '//{print $3}') # starting loop to delete all classes for class in $classID;do # sleep to prevent server overload (commented out for testing) # sleep 1 # log delete attmpt and report to user echo echo "$(date) - Deleting class ID $class" >> /tmp/classes_deleted.txt echo "Deleting class ID $class" # checking bearer token expiration # delete class via API if [[ "$count" -lt "100" ]]; then checkTokenExpiration /usr/bin/curl -k --silent --header "Authorization: Bearer ${bearerToken}" ${jamfpro_url}/JSSResource/classes/id/$class/action/deleteNoRefresh --request DELETE ((count++)) echo else checkTokenExpiration /usr/bin/curl -k --silent --header "Authorization: Bearer ${bearerToken}" ${jamfpro_url}/JSSResource/classes/id/$class --request DELETE count=0 echo fi done #create class for refresh XML='Temp1234Temp' echo echo "Creating Temp1234 class to force the class refresh in Jamf Pro" echo checkTokenExpiration newClass=$(curl --silent --header "Authorization: Bearer ${bearerToken}" --header "Content-type: text/xml" $jamfpro_url/JSSResource/classes/id/1 -X POST -d "$XML" ) newClassID=$(echo "$newClass" | xmllint --format - | awk -F '[<>]' '//{print $3}') echo echo "30 second pause to confirm tenant sync" echo sleep 30 # delete new class via API echo echo "Deleting Temp1234 class." echo checkTokenExpiration /usr/bin/curl --silent --header "Authorization: Bearer ${bearerToken}" ${jamfpro_url}/JSSResource/classes/id/$newClassID --request DELETE echo echo "All classes have been deleted." echo # Invalidate bearer token (keep this at the end of the script) echo "Invalidating bearer token..." invalidateToken exit
