Connecting Okta as an LDAP Source
  • August 27, 2024
  • 5 replies
  • 76 views
Hello,
Currently, we have an LDAP server configured with our on-premises Active Directory, and all user information is being retrieved from there. However, in the coming months, we will no longer be using on-premises Active Directory. We also have Okta in place. How can we configure LDAP with Okta so that Jamf can retrieve all user information from Okta?
Do you have any updated documentation we can use as a reference?
DBrowning
  • August 27, 2024
https://travellingtechguy.blog/integrating-okta-ldap-in-jamf-pro/
Be careful.  When we tried setting this up we were hitting the connection limit (Okta limitations) within like 2 minutes.
  • August 27, 2024
@DBrowning I saw this link, but it's from 2020, so I'm not sure if it still works. Were you able to resolve these Okta limitations by any chance?
DBrowning
  • August 27, 2024
We were not.  The hard limits are set globally by Okta.  We ended up using Entra instead.
  • August 27, 2024
@DBrowning We are also using Microsoft Intune. Is there any way we can use Intune as LDAP? If so, do you have any reference documentation? Thanks in advance.
DBrowning
  • August 27, 2024
Intune is not a LDAP service.  Entra ID (Azure AD) is.  https://learn.jamf.com/en-US/bundle/jamf-pro-documentation-current/page/Azure_AD_Integration.html#ID-00005db2
