Authorization Key for scripts executed via Casper Remote
  • September 8, 2017
  • 12 views
dan-snelson
Forum|alt.badge.img+30
Background
We allow our upper-tier TSRs to execute scripts via Casper Remote, but we don't allow them to view the actual scripts in the JSS.
Occasionally, a TSR will execute a script via Casper Remote which I really wish they hadn't, so we came up with an "Authorization Key" for our more impactful scripts.
Concept
Use a Script Parameter to check for some random string of characters before allowing a script to execute.
Implementation & Script
Add an if then else to your script which checks for some random string of characters. If the passed Script Parameter doesn't match, exit; if it does match, proceed.
Casper Remote
The Casper Remote user must enter the correct random string of characters to execute the script. (Authorized JSS admins can easily lookup the random string of characters before adding the script to a policy.)
Script
# ABOUT
#   This script will forcibly remove all Configuration Profiles. (Used in preparation to migrate
#   a computer from the JAMF Software Server 9.x to the Jamf Pro Server 10.x
# HISTORY
#   Version 1.0, 08-Sep-2017, Dan K. Snelson
### Variables
authorizationKey="$4"
# Check for a specified value in Parameter 4
if [ "$authorizationKey" != "rs2y3hng1O8kIsz2GiiAN" ]; then
    echo "Error: Incorrect Authorization Key; exiting."
    exit 1
    echo "Removing Configuration Profiles ..."
    /bin/rm -Rfv /var/db/ConfigurationProfiles
    echo "Configuration Profiles removed."
Casper Remote Log showing error to Casper Remote user
Running script removeProfiles.sh...
Script exit code: 1
Script result: Error: Incorrect Authorization Key; exiting.
Error running script: return code was 1.
1 reply
  • February 10, 2020
@dan-snelson Thank you for sharing this ingenious usage to be able to give techs enough power to do their jobs but not so much power that they can cause real harm without at least some opportunity for oversight!
