Patch Management - Spotify Latest Version is Incorrect
  • September 17, 2024
  • 5 replies
  • 106 views
In Patch Management Spotify is indicating that version 1.2.43.420 is the latest version even though 2 newer versions have been released since that one.  Can this be fixed to display the correct latest version.
Best answer by ahilla
I put a support ticket in... no response... but it appears to be fixed now.
A_Collins
I believe you better raise this one with Jamf as this is community portal not jamf support.
pete_c
Under Mac Apps in my sandbox, Spotify shows as 1.2.45.454, and client devices receiving that update show that version. I’ve found MA to be a better and more reliable resource for smaller groups and simpler apps.
  • September 18, 2024
Thanks, I submitted a case with support.  In the past I've had employees also reach out in community.
For the most part I'm using Patch Management for tracking of what version of the app is installed and then using Installomator for patching.  I may move some applications to Mac Apps in the future, however the addition of more applications into the Jamf App Catalog has seemed slow.
  • September 20, 2024
