Darshan Hiranandani : can I use grep to find a profile with a name that consists of multiple words?
  • September 19, 2024
  • 4 replies
  • 59 views
I’m currently developing a remediation policy for Self Service that triggers the uninstall and reinstall of a profile. While I can successfully remove and reinstall the profile, I need a verification step to check if the profile was reinstalled. I'm using the following command:
bash
profiles show -o stdout | grep "ProfileDisplayName = "$profileName"" | /usr/bin/awk '{print $3}' | sed 's/[[:punct:]]//g'
This works perfectly for single-word profile names, like "Zoom," but fails with multi-word names, such as "Zoom Profile," resulting in "no such file or directory." I’ve tried enclosing the profile name in both single and double quotes, and using "${profileName}", but nothing seems to work.
Could anyone suggest how to modify the command so it successfully handles profile names with more than one word? Here’s the function I created for verification:
bash
function checkInstall() {
installed=$(profiles show -o stdout | grep "ProfileDisplayName = "$profileName"" | /usr/bin/awk '{print $3}' | sed 's/[[:punct:]]//g')
if [ "$installed" = "$profileName" ]; then
log "Profile "$profileName" was installed successfully"
elif [ "$installed" != "$profileName" ]; then
log "Profile "$profileName" install failed"
Thanks for your help!
Regards
Darshan Hiranandani
You’re probably be better off grepping for the UUID of the profile instead.
AJPinto
Almost this exact question was asked last week, strange. However, there is a solution in that post you should probably look at.
Solved: How to grep a profile named with more than one wor... - Jamf Nation Community - 324834
I tend to prefer the unique identifier as the profile name can change, it also avoids issues with non-alpha characters
Shyamsundar
  • October 8, 2024
try this
profiles show -o stdout | grep "ProfileDisplayName" | grep "$profileName"
