Support for Safari Extension management on Macos 15
  • September 23, 2024
  • 181 views
Hey, Macos 15 (and IOS 18) add support for controlling Safari extensions enablement using DDM -
https://developer.apple.com/documentation/devicemanagement/safariextensionsettings
Is it supported on jamf already? didn't see anything about it in the recent release notes. If not, any plan to add jamf support for this configuration anytime soon?
AJPinto
I have not heard anything about Jamf adding support for this. Just be aware that "day 0 support" is an advertising gimmick that basically means the most basic form of management will be available at the day of launch. Less core functions like this are usually not released until Spring.
Shyamsundar
  • October 9, 2024
We might get it as part of BluePrint maybe on 11.11
  • January 21, 2025
Hey, any one have an update on this feature?
