When my dualboot imaging (using a .winclone bootcamp image) is complete the OSX partition is not mounted but the Bootcamp partition is fine. I ran Verify Disk on the partition and get "invalid b-tree node size" and Repair Disk is unable to repair the partition. I have opened a call with Casper but thought I would give this forum a shot. Any help is appreciated. I will attach a screenshot of the Casper configuration.http://people.musc.edu/~awa2
is there a way to post an attachment directly to this site without having to link it to an external URL?
I was able to extract the .Winclone Bootcamp image in OSX (using the winclone_helper_tool) after I manually created a FAT partition to install it on. So I know the Winclone bundle is OK.
The fix for this was to used the winclone pkg format and to check the "install on boot drive after imaging" box for the package.
