Password for Pre-stage enrollment
  • September 27, 2024
  • 24 views
Hello guys,
I would like to set a password to pass the prestage enrollement page. I can't find anything on this topic. Do you have any ideas? Thanks.
Best answer by AJPinto
There is an option in the prestage under general to require authentication for enrollment. By default it uses local Jamf Accounts, but also supports LDAP. You can also enable an enrollment customization to use your IDP with SSO for authentication.
1 reply
AJPinto
