trusted root certificates removed after iOS 18 on iPads
  • October 1, 2024
  • 4 replies
  • 317 views
After upgrading to iOS 18, students are seeing trusted certificates being removed from their iPads.  In our case, they are root certificates that get pushed via Jamf Pro during enrolment - one for wifi access, one is the JSS built in certificate.
(click on settings, about, certificate trust settings to see the certificates that get pushed)
Is anyone else seeing this please?  We are seeing this sitewide, as the OS update rolls out.
No fix at the moment other than wipe the device and enrol all over again to get the certificates back - not feasible when you have over 1000 iPads!
  • October 6, 2024
Yes, this seems to be a known issue with iOS 18 where trusted certificates are being removed after the upgrade. Unfortunately, the only current workaround is to wipe and re-enroll devices, which isn’t feasible for large deployments. Monitor the Jamf community for updates or patches, and consider reporting this issue to both Jamf and Apple for quicker resolution. Hope! it would be helpful.
  • December 10, 2024
We are still seeing this issue even on iPads running 18.1.1.  I even tried to manually reinstall the certificate that was not trusted and the option to trust it just never shows up under Settings > General > About > Certificate Trust Settings.  However, not all of our iPads are impacted.
  • December 11, 2024
Thanks for the heads up. We are seeing the same - not all are impacted but we cannot find a common thread that links the ones that are impacted.
  • March 13, 2025
We have experienced the same issue. About half of our devices updated at one point and got IOS 18.1.1. Because we use Securly, we got a ton of issues with network connectivity.
It would seem Apple has silently resolved this issue in IOS 18.2 and newer. If you are running IOS 18.0-18.1.1, consider updating to 18.2 or newer.
