FEATURE REQUEST
  • October 3, 2024
  • 4 replies
  • 72 views
Please create a Self Service app/web clip that allows user to update inventory from their device.
Best answer by AJPinto
Have you already submitted a feature request that you could link? People can upvote feature requests you submit to help draw attention to them.
AJPinto
  • October 3, 2024
dvasquez
  • October 3, 2024
You can also do this by creating a self-service policy leveraging the Files and Processes payload and setting a nice icon. Seems, like this will do exactly what you are asking but it is not a web click specifically.
Good Luck
  1. Policies
  2. User > Files and Processes
  3. put the jamf recon command in place
  4. Set it to self service
  5. Set scope
  6. Set icon
  7. Save and test
  8.
  9.
sdagley
  • October 3, 2024
@cgries A Policy that can be triggered via Self Service that has only a Maintenance payload with Update Inventory enabled does what you're asking so I'm not sure why a Feature Request would be necessary.
  • October 6, 2024
Hello,
We have something like this in our environment. I will paste what we have below and you can see if it might work for you.
It is a Python script running on a Mac mini with a static IP and some ports forwarded to an A record on the firewall. It allows a web clip for both blank push and inventory on iPads. It could be created for Macs as well with some slight modifications.
Here is the script:
#!/usr/local/bin/python
from flask import Flask
import requests
import time
app = Flask(__name__)
jss_user = 'API CONNECTION USERNAME HERE'
jss_pass = 'API CONNECTION PASSWORD HERE'
jss_url = 'YOUR JAMF URL HERE'
logo_url = 'YOUR APP LOGO HERE'
logo_width = '40%'
text_color = 'color:#002664'
@app.route("/")
def hello():
return "JSS Remote Commands Utility"
@app.route('/update/<id>')
def update_inventory(id):
url = jss_url+'/JSSResource/mobiledevicecommands/command/UpdateInventory/id/' + id
r = requests.post(url, auth=(jss_user,jss_pass), verify=True)
return "<html><body><center><br/><br/><img src="+logo_url+" width="+logo_width+"><h1 style="+text_color+">Update Inventory Request Sent</h1><br/><h2 style="+text_color+">The inventory process may take up to 5 minutes.<br/>You may return to the Home Screen at this time, but do not lock this iPad.</h2></center></body></html>"
@app.route('/push/<id>')
def blank_push(id):
url = jss_url+'/JSSResource/mobiledevicecommands/command/BlankPush/id/' + id
return "<html><body><center><br/><br/><img src="+logo_url+" width="+logo_width+"><h1 style="+text_color+">Blank Push Request Sent</h1><br/><h2 style="+text_color+">Any pending commands for this device will be received within 5 minutes.<br/>You may return to the Home Screen at this time, but do not lock this iPad.</h2></center></body></html>"
if __name__ == "__main__":
app.run(host='0.0.0.0', port=8000, debug=False)
Here is the JAMF side of things:
http://YourARecordHere:YourPortHere/update/$JSSID
Here is the firewall information:
We have a firewall rule that says from any source pointing to the A record, send it to the local IP and ONLY allow the service "python". This is with a Fortigate so your usage may be different.
Hope this helps!
