Extension Attribute to identify systems with Windows
  • August 29, 2012
  • 54 views
Hi all,
I am looking to set up an Inventory Search to identify system running our Windows Image for I can set up a smart group of those particular systems, I am thinking I will need an Extension Attribute - has anyone done something similar to this before?
Thanks
Matt
Best answer by mjames
I believe I have found my own solution.
I have just altered the Extension Attribute script that looks for the Recovery Partition, to search for our Windows drive name instead.
  • August 29, 2012
chris_kemp
Forum|alt.badge.img+20
  • August 29, 2012
I believe you could also simply specify search criteria as:
OS Configuration Information -> Operating System -> not like OS X
Forum|alt.badge.img+31
  • August 30, 2012
Hey Matt,
Chiming in a bit late here, but back in like 2008 or 2009 I deployed Windows to a ton of Macs. They were a dual boot configuration. We had to have Windows and a dual boot config to run a specific application, so I used a dummy receipt system (this was pre Extension Attributes) to track if they had an NTFS partition or not. Then I could scope saved searches by if they had the dummy receipt or not.
I just used the `df` command. You could do something similar, here is my example (note I don't have a NTFS system available):
df -T hfs
Filesystem   512-blocks      Used Available Capacity  Mounted on
/dev/disk0s2  975093952 232630808 741951144    24%    /
/dev/disk1s1     204720    147456     57264    73%    /Volumes/Casper Suite SDK - November 2011
/dev/disk2s1     204720     95288    109432    47%    /Volumes/Resource Kit - November 2011
So, if you did a df -T ntfs it should list any ntfs partitions present. From there you can grep, awk, or check exit status to see if one is present.
If you don't have a working solution, hopefully this may help.
Thanks,
Tom
