[Feature Request] - Ability to export jamf pro resource to terraform resource templates
  • October 22, 2024
  • 78 views
As one of the maintainers of the Jamf Pro terraform plugin here  i'd like to request a new feature to assist with creating Jamf Pro based terraform resources as templates, whereby there would be the ability to export from the gui a template of existing resources into HCL (hashicorp configuration language).
The exported template would help admins understand the HCL syntax and properties that deploy admin's resources. The exported template would function as a starting point for new and existing users of the plugin and would act as a basis from which it can be modified for the admin's specific scenario. The exported resource template process would attempt to create a usable template from the off and would be autogenerated, however there would be an understanding that exported templates could still require some modifications before they can be used to deploy Jamf Pro resources.
The feature request would enable admin's to pick one or more resources from the gui for exporting to a terraform resource template, this would especially useful for more complex resource types such as policies.
This feature exists within Azure, see the example below:
Best answer by Dafydd_Watkins
Raised this correctly here - https://ideas.jamf.com/ideas/JPRO-I-783
1 reply
  • October 22, 2024
