Safari extension
  • October 31, 2024
  • 6 replies
  • 96 views
shrisivakumaran
Hi All,
does anyone know/have extension attributes to find installed extension in Safari browser?
MPL
  • October 31, 2024
We don't use this anymore, but we used to use it. Last time we did, it worked fairly well:
  • To note, I think python will need to be on the systems
#!/usr/local/bin/managed_python3 # Name: safari_extensions.py # Description: This extension attribute returns a list of the names and # versions of all Safari add-ons installed for the current # user. Inspired by the managed_python3 version of Chrome Extensions script by Elliot Jordan <elliot@lindegroup.com> # Author: Daniel Mortensen <dmortensen@simonsfoundation.org> # Created: 2022-10-28 # Last Modified: 2022-10-28 # Version: 1.0 import os import xml.etree.ElementTree as ET import re import sys from SystemConfiguration import SCDynamicStoreCopyConsoleUser def get_current_user(): username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0] return username def get_extensions(username): extensions_list = ("/Users/%s/Library/Containers/com.apple.Safari/" "Data/Library/Safari/AppExtensions/Extensions.plist" % username) return extensions_list def print_results(extensions_list): tree = ET.parse(extensions_list) root = tree.getroot() list = "" for key in root.iter('key'): match = re.search('com.',key.text) if match: result = key.text list = list + result + "\\n" return list.strip() def main(): username = get_current_user() extensions_list = get_extensions(username) #results = parse_results(manifest_list) to_echo = print_results(extensions_list) print("<result>%s</result>" % to_echo) if __name__ == '__main__': main()
  • October 31, 2024
I use this script, the only rub is it may still list an extension in the plist after you've already removed it.
user=$(stat -f%Su /dev/console)
extensions_list="/Users/$user/Library/Containers/com.apple.Safari/Data/Library/Safari/WebExtensions/Extensions.plist"
ExtensionCheck=$( /bin/cat $extensions_list | /usr/bin/grep key | /usr/bin/grep extension)
echo "<result>$ExtensionCheck</result>"
pete_c
  • October 31, 2024
I recently had need to deploy this: https://community.jamf.com/t5/jamf-pro/can-support-ea-for-this-script/m-p/321992/highlight/true#M277878
Should be easy to tailor for only Safari.
shrisivakumaran
This scripts returns empty value when I run from Jamf EA.
when I run locally it return cat: /Users/sivakum/Library/Containers/com.apple.Safari/Data/Library/Safari/WebExtensions/Extensions.plist: Operation not permitted
shrisivakumaran
This requires python in all system
shrisivakumaran
tried this but for Safari it not gives enough details
