Repair: We encountered an error while adding account. Please try again.
  • November 8, 2024
  • 5 replies
  • 568 views
bwoods
Posting this for anyone experiencing an Office 365 login loop (Usually happens with Outlook). If reverting to legacy Outlook doesn't resolve your issue, run the keychain removal script below. It will restart the device. (The script is sourced from Scott Feit on the MacAdmins Slack channel and has resolved the issue multiple times for me)
#!/bin/bash # Define the target directory TARGET_DIR="$HOME/Library/Keychains" # Function to log messages log_message() { echo "$(date +"%Y-%m-%d %H:%M:%S") - $1" } # Close the Keychain Access app log_message "Closing Keychain Access application." pkill -x "Keychain Access" # Check if the target directory exists if [ -d "$TARGET_DIR" ]; then log_message "Starting cleanup of directories in $TARGET_DIR" success_count=0 fail_count=0 # Find all directories within the target directory and delete them, logging each action find "$TARGET_DIR" -type d -mindepth 1 -print0 | while IFS= read -r -d $'\\0' dir; do rm -rf "$dir" if [ $? -eq 0 ]; then log_message "Successfully deleted directory: $dir" ((success_count++)) else log_message "Failed to delete directory: $dir" ((fail_count++)) fi done if [ $fail_count -eq 0 ]; then log_message "Cleanup completed successfully. Running 'sudo jamf recon'." # Run jamf recon sudo jamf recon log_message "Initiating forced restart with 15-second delay." # Display a popup message with a 15-second timer before the restart osascript -e 'tell app "System Events" to display dialog "Your computer will restart in 15 seconds." buttons {"OK"} default button 1 giving up after 15' # Wait for 15 seconds before the restart sleep 15 # Force a restart of the computer sudo shutdown -r now "Script-initiated forced restart." else log_message "Cleanup completed with $fail_count failures. Restart aborted." fi else log_message "Target directory does not exist. No actions were taken." fi
sdagley
  • November 9, 2024
@bwoods Is this error occurring when first enrolling a Mac and licensing is via an M365 account instead of a VL? If so, if you launch another office app (e.g. Word) before launching Outlook does Outlook then successfully create the account?
bwoods
  • November 9, 2024
Sometimes I do see this at enrollment and reverting Outlook fixes the issue. Other times I see it for users that have been enrolled for quite awhile. (Other apps are already signed in) Office Reset & reinstallation don't work for those cases. This script is what I use when the loop just won't seem to go away. Hope this helps someone out there. Thank you.
sdagley
  • November 9, 2024
Thanks for the extra details. It sounds like the problem you're seeing with Outlook is not the same one that's been biting me for the past several months.
Jason33
  • November 10, 2024
Outlook has been bad for use since September, but it got much worse in early October. We shut down our express route to Microsoft on Oct 1, and from then on, the standard Outlook no longer wants to show contents of the user inbox or shared mailboxes; for inboxes that do load, new email will come in, but any new email or replies are stuck in the Outbox; activations failing. Like you said, the only resolution for most of these is to switch to Legacy Outlook. I've got a ticket open with Microsoft and their 'suggestion' is for use to whitelist there entire list of URL's, and our security team is not having that.
mvu
Forum|alt.badge.img+21
  • November 12, 2024
Thanks. Ran into this here and there. Will bookmark and use.
