MacOS Onboarding - Extension attribute
  • November 18, 2024
  • 45 views
tdenton
Just setup MacOS onboarding and working great for use.
As anyone configured the MacOS Onboarding extension attribute mentioned here https://www.motionbug.com/jamf-pro-and-macos-onboarding/
This does'nt appears to create tag usisng  touch /Library/Application Support/JAMF/.onboardingcomplete. I assume thats what its suppose to do, unsure if the path is correct shouldnt it be
touch /Library/Application\\ Support/JAMF/.onboardingcomplete
Doesnt create the file either way assuming thats what its suppose to do.
Anyone got this working? think I missing something simple.
Thanks
Tom
Best answer by tdenton
answered my own question
its a hidden file and this does appear to be correct path touch /Library/Application\\ Support/JAMF/.onboardingcomplete after an inventory update gets updated.
1 reply
tdenton
  • November 18, 2024
