mac app store apps and smart groups as target
  • November 25, 2024
  • 5 replies
  • 106 views
JevermannNG
Just wondering if I missed something ...
Could it be that Apps from the Mac App Store do not work with Smart Groups in Jamf Pro 11.11 ?
Since changing the target for some MS Office Apps to a Smart Group, those Apps do not receive any Updates on the Macs in the scope of the Smart Group.
The MDM Management history looks like this:
Best answer by JevermannNG
It turned out that it was a mix up of the Target Smart Group and the Site.
After setting the Site to "None" it worked again ...
Thanks for the quick response.
AJPinto
  • November 25, 2024
Free apps still need licenses. I see that you have 500 licenses for Remote Desktop but OneDrive which you are having issues with does not look to have assigned licenses.
Shyamsundar
  • November 25, 2024
Check Assign Content Purchased in Volume Check box is Selected at Managed Distribution tab
JevermannNG
  • November 25, 2024
I have also 500 licenses for those Apps, but since switching to a smart groups as target, the licenses do not show up in Jamf:
JevermannNG
  • November 25, 2024
The Licenses were assigned before switching the Targets to a Smart Group, but it looks like that they got lost now ...
I just created a new OneDrive Mac App Store Distribution in Jamf with no target at all, the result is like expected:
JevermannNG
  • November 29, 2024
