iOS 18 Configuration Profile: Allowed Apps and usage of AirDrop
  • December 4, 2024
  • 6 replies
  • 285 views
fab_dre
Hello,
we have a lot of iPads for a special use case. Therefore the devices are very restricted.
We are using a configuration profile with a home screen layout and restrictions for Apps.
We restricted many apps and especially we are using the function "App usage" with "Only some apps allowed".
Since iOS 18 it's no longer possible to send a document via Airdrop to this device. The sound of reception is heard but no notification appears to allow the document. The status on the other device which send the document is "waiting".
It works again, if I remove the function "app usage" from configuration profile.
Is there any option to add AirDrop or the notification to "allowed apps"? Or is there any other workaround to use this function with AirDrop?
Best regards
Fabian
Best answer by tmtech
This issue can be resolved by adding "com.apple.Sharing.AirDropUI" to the list of allowed apps.
  • December 5, 2024
were can i find this confiuration?
fab_dre
  • December 5, 2024
Configuration Profile - Restrictions - Apps => Scroll down to "App Usage"
frank_arena
  • January 21, 2025
I too am having this same issue. Can't seem to find any info as to what to allow in order to receive an AirDrop notification.
  • January 21, 2025
fab_dre
  • January 22, 2025
Thanks for the hint. I was looking for a solution like this and will try it.
The current workaround is to use the restriction "Some apps not allowed".
frank_arena
  • January 22, 2025
The workaround is what I used. The AirDrop bundle ID provided by @tmtech works beautifully. Thank you!
