EA/Smart Group to determine if a user has accessed Terminal
  • December 12, 2024
  • 6 replies
  • 66 views
I've created an EA with the script
#!/bin/bash echo "$(mdls "/System/Applications/Utilities/Terminal.app" -name kMDItemLastUsedDate | awk '{print $3}')"
and running it on my device, it returns
2024-12-12
as expected. I then created a Smart Group with Criteria <Name of EA>, Operator 'after (yyyy-mm-dd)' and Value '2024-01-1'. Jamf returns a list of devices but I do not believe this list is accurate, as it does not include my device when I've been using Terminal all morning.
Any suggestions on what could be happening or what I can do to improve its accuracy?
Best answer by karthikeyan_mac
Hi @blee,
 Result of EA should be within <result>value</result>. This could also be an issue.
#!/bin/bash echo "<result>$(mdls "/System/Applications/Utilities/Terminal.app" -name kMDItemLastUsedDate | awk '{print $3}')</result>"
Thanks
karthikeyan_mac
Forum|alt.badge.img+20
  • December 12, 2024
Hi @blee,
Thanks
Shyamsundar
  • December 12, 2024
you need to change the date format to YYYY-MM-DD hh:mm:ss , and also you need to select your data type as DATE in the EA, try this
#!/bin/bash date=$(mdls -r -name kMDItemLastUsedDate /System/Applications/Utilities/Terminal.app) formattedDate=$(date -juf "%F %T %z" "$date" "+%F %T") echo "<result>$formattedDate</result>"
  • December 12, 2024
Thanks for the suggestion. I've tried your script and updated my EA (also double checked that Data Type is YYYY-MM-DD hh:mm:ss) but I'm getting the same results (my device is still not listed with the new script). In the Smart Group criteria I've selected "after (yyyy-mm-dd)" as the Operator and 2024-01-01 as the Value.
Any ideas? If it can show my device in the results list I can at least it's accurate to some degree.
sdagley
  • December 12, 2024
@blee Be aware that if you don't return a properly formatted date in the response from an EA that is configured to have a date result then your JSS will not be happy. Here's an example EA that makes sure a valid date is always returned:
#!/bin/sh AppToCheck="/System/Applications/Mail.app" result="2000-01-01 00:00:01" if [ -d "${AppToCheck}" ]; then AppLaunchTime=$(mdls -name kMDItemLastUsedDate "${AppToCheck}" | cut -f 3,4 -d \\ ) validTime=$(echo "$AppLaunchTime" | grep "null" ) if [ -z "$validTime" ]; then result="$AppLaunchTime" fi fi echo "<result>$result</result>"
pete_c
  • December 13, 2024
Also remember that results of an EA are only returned when recon runs.
  • December 13, 2024
thank you @karthikeyan_mac @Shyamsundar and @sdagley for the suggestions! The script is working, and @pete_c 's note about EAs returning when recon runs was the final nail in the coffin. Kudos to all
