Run Bootstrap Token Escrow Script
  • December 18, 2024
  • 8 replies
  • 942 views
We have a number of machines that don't have the bootstrap token escrowed. I'm trying to provide a self-service option by having someone run the script from Self-Service. My understanding is that the scripts would run as root, but I'm getting the error:
Script result: Enter the admin user name:Error: Missing user name.
profiles: Unable to authenticate user information.
Do scripts run in a policy not run with root access?
wakco11
  • December 18, 2024
The command profiles install -type bootstraptoken requires an admin login at the command line, as well as being executed as root. This means to script it, an expect script must be used, to pass the admin login details to the command through std-in. And as such, it's not very secure.
  • December 19, 2024
Any suggestions on how to handle it then?
  • December 21, 2024
I have had some success with this script.  I found this on other sites..I cannot take credit for this):
#!/bin/sh # Set the icons and branding selfServiceBrandIcon="/Users/$3/Library/Application Support/com.jamfsoftware.selfservice.mac/Documents/Images/brandingimage.png" fileVaultIcon="/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/FileVaultIcon.icns" if [[ -f $selfServiceBrandIcon ]]; then brandIcon="$selfServiceBrandIcon" else brandIcon="$fileVaultIcon" fi # Start by setting result to UNDEFINED result="UNDEFINED" MissingSecureTokenCheck() { # Get the currently logged-in user and go ahead if not root. userName=$(/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }') # This function checks if the logged-in user has Secure Token attribute associated # with their account. If the token_status variable returns "0", then YES is set. # If anything else is returned, NO is set. if [[ -n "${userName}" && "${userName}" != "root" ]]; then # Get the Secure Token status. token_status=$(/usr/sbin/sysadminctl -secureTokenStatus "${userName}" 2>&1 | /usr/bin/grep -ic enabled) # If there is no secure token associated with the logged-in account, # the token_status variable should return "0". if [[ "$token_status" -eq 0 ]]; then result="NO" fi # If there is a secure token associated with the logged-in account, # the token_status variable should return "1". if [[ "$token_status" -eq 1 ]]; then result="YES" fi fi # If unable to determine the logged-in user # or if the logged-in user is root, then UNDEFINED is returned } MissingSecureTokenCheck if [[ $result = "NO" ]]; then # Current user does not have a secure token. Need to generate one. # Granting user needs to be an admin. Get all the admin users on the computer. adminUsers=$(dscl . read /Groups/admin GroupMembership | cut -d " " -f 2-) # For each user, check if they have a secure token for EachUser in $adminUsers; do TokenValue=$(sysadminctl -secureTokenStatus $EachUser 2>&1) if [[ $TokenValue = *"ENABLED"* ]]; then SecureTokenUsers+=($EachUser) fi done # List out the users with a secure token if [[ -z "${SecureTokenUsers[@]}" ]]; then # If no secure token admin users, show dialog stating such /usr/bin/osascript -e "display dialog \\"\\" & return & \\"There are no secure token admin users on this device.\\" with title \\"Grant Secure Token\\" buttons {\\"OK\\"} default button 1 with icon POSIX file \\"$brandIcon\\"" exit 0 else # Have user select a secure token user they know the password for adminUser=$( osascript -e "set ASlist to the paragraphs of \\"$(printf '%s\\n' "${SecureTokenUsers[@]}")\\"" -e 'return choose from list ASlist with prompt "Select a user you know the password for:"' ) # Get a secure token users password adminPassword=$( /usr/bin/osascript -e "display dialog \\"To grant a secure token\\" & return & \\"Enter login password for '$adminUser'\\" default answer \\"\\" with title \\"Grant Secure Token\\" buttons {\\"Cancel\\", \\"Ok\\"} default button 2 with icon POSIX file \\"$brandIcon\\" with text and hidden answer set adminPassword to text returned of the result return adminPassword") # Exit if user cancels if [ "$?" != "0" ] ; then echo "User aborted. Exiting…" exit 0 fi fi # Try the entered password passCheck=`dscl /Local/Default -authonly "${adminUser}" "${adminPassword}"` # If the credentials pass, continue, if not, tell user password is incorrect and exit. if [ "$passCheck" == "" ]; then echo "Password Verified" else echo "Password Verification Failed. Please try again." /usr/bin/osascript -e "display dialog \\"\\" & return & \\"Password Verification Failed. Please try again.\\" with title \\"Grant Secure Token\\" buttons {\\"OK\\"} default button 1 with icon POSIX file \\"$brandIcon\\"" exit 1 fi # Get the logged in user's password via a prompt echo "Prompting ${userName} for their login password." userPassword=$( /usr/bin/osascript -e "display dialog \\"To grant a secure token\\" & return & \\"Enter login password for '$userName'\\" default answer \\"\\" with title \\"Grant Secure Token\\" buttons {\\"Cancel\\", \\"Ok\\"} default button 2 with icon POSIX file \\"$brandIcon\\" with text and hidden answer set userPassword to text returned of the result return userPassword") # Exit if user cancels if [ "$?" != "0" ] ; then echo "User aborted. Exiting…" exit 0 fi echo "Granting secure token." # Grant the token sysadminctl -secureTokenOn ${userName} -password ${userPassword} -adminUser ${adminUser} -adminPassword ${adminPassword} # Check for bootstrap token escrowed with Jamf Pro bootstrap=$(profiles status -type bootstraptoken) if [[ $bootstrap == *"escrowed to server: YES"* ]]; then echo "Bootstrap token already escrowed with Jamf Pro!" else # Escrow bootstrap token with Jamf Pro echo "No Bootstrap token present. Escrowing with Jamf Pro now…" sudo profiles install -type bootstraptoken -user "${adminUser}" -pass "${adminPassword}" fi elif [[ $result = "YES" ]]; then echo "Current user already has a secure token. No action necessary." /usr/bin/osascript -e "display dialog \\"\\" & return & \\"$userName already has a secure token. No action necessary.\\" with title \\"Grant Secure Token\\" buttons {\\"OK\\"} default button 1 with icon POSIX file \\"$brandIcon\\"" else echo "Undefined secure token status" /usr/bin/osascript -e "display dialog \\"\\" & return & \\"Could not determine secure token status.\\" with title \\"Grant Secure Token\\" buttons {\\"OK\\"} default button 1 with icon POSIX file \\"$brandIcon\\"" exit 1 fi
  • December 22, 2024
That script is quite lengthy. Wow the brains behind it. So I can just test it on my end by copying it as is?
  • December 22, 2024
Theoretically it should work just fine that way. I had 4 users that didn’t have valid tokens and this worked great on one of them. The others haven’t checked in for over a month so cannot verify success on those Mac’s yet. 😢
Get Outlook for iOS<>
  • December 22, 2024
I tried using this script and it does work in many cases. However, according to the author it will only escrow a bootstrap token if a secure token needs to be created. If it's already been created it won't escrow it.
  • December 23, 2024
That is correct..there has to be at least one user on the system that has secure token rights (it is usally the very first person that setups the computer) that has admin rights and secure token rights and then the bootstrap token can be granted to others…
get2brad-sdm
  • February 6, 2025
I deployed this today (after making a few adjustments to the scripts which were just merged). So far, my few tests are working great. It's available via Self Service scoped to machines that do not have the bootstrap token escrowed. I'm pleased so far.
