CIS Baseline with PSSO
  • January 3, 2025
  • 149 views
RDowson
We’re deploying the CIS L1 baseline to Macs which are using the new Platform SSO with Entra.
What’s the best practice in terms of password policy within the CIS baseline? Should we exclude these policies or does using PSSO override them anyway?
I don’t want to end up on a situation where the baseline password policies are more restrictive than the company password policy from Entra and have that causing issues with password syncing.
Best answer by AndrewNe
It's certainly sensible to be mindful of how Entra ID and macOS handle password policies differently, it can sometimes be a challenge to get them aligned just right. You've got five password policy related items in CIS Level 1 which can be automated;
  • 5.2.1 - Limit Consecutive Failed Login Attempts to $ODV
  • 5.2.1 - Set Account Lockout Time to $ODV Minutes
  • 5.2.8 - Prohibit Password Reuse for a Minimum of $ODV Generations
  • 5.2.7 - Restrict Maximum Password Lifetime to $ODV Days
  • 5.2.2 - Require a Minimum Password Length of $ODV Characters
Of these, both 5.2.1 items and 5.2.2 have little scope for clashing if set as or less restrictive than Entra ID. It's 5.2.8 and 5.2.7 which may end up running on a different timing "cycle". For 5.2.7 you're pretty safe unless you have a minimum password lifetime value set, worst case scenario the user has to change their password more frequently than they otherwise might. This leaves 5.2.8, this could cause issues, however it depends on your password policies as to whether there is a significant likelihood of this happening.
As for what the interaction between your password policy and Platform SSO will be, that largely depends on which "flavour" of PSSO you're going with as each interacts differently with the local account password.
In summary, I think there isn't much in the CIS Level 1 which is likely to cause issues for end users, other than potentially 5.2.8 in some cases. It is an acceptable approach to modifying the CIS recommendations if you have good reason to, or if you have mitigations elsewhere which help to address a given control. Make sure that you document where you diverge from the recommendations, Jamf Compliance Editor is a really good way to manage this and it will even create custom documentation for your modified baseline. https://trusted.jamf.com/docs/establishing-compliance-baselines
  • Employee
  • January 3, 2025
RDowson
  • January 3, 2025
Very helpful, thank you.
  • July 22, 2025
Is the local password not independent from the PSSO ? First deploy local user with your respective settings in JAMF for passwords and then sign into entra via PSSO. At this point I would use secure enclave key method. Then there are two independent sign-ins. CIS Level 1 would only monitor the local password and not the passwordless sign in.
Or am I missing something.
I am planning the same scenario so it would be super nice if you could share if you used the password less approach.
