Updating Visual Studio Code on Macs for not admin User
  • January 14, 2025
  • 7 replies
  • 1102 views
Jacek_ADC
Hello there,
maybe someone has an idea for solving this issue. We have started to enroll MacBooks to employees without admin rights. We was using first the visual studio code installer from jamf mac apps. The problem with this, is that i cant add some configuratio (for example creating a symlink for this app) within the jamf mac app installer config.
So at the moment i am using a normal policy with a pkg for vscode. Everything until here is working fine.
When an update is released for vscode, the user (without admin right) can't install it. The first window which pops up is for the helper tool (updater) for visual studio code
 So i was searching for a solution and found this page here, which explains this problem:
https://github.com/microsoft/vscode/issues/115805
I am able to do all this changes for the group and ownership for the logged in user but the problem still persist.
My script
#!/bin/bash set -x # Get the current user's home directory loggedInUser=$(stat -f "%Su" /dev/console) USER_HOME="/Users/$loggedInUser" echo $USER_HOME echo $loggedInUser # Path to Visual Studio Code binary VSCODE_BIN="/Applications/Visual Studio Code.app/Contents/Resources/app/bin/code" # Target symlink location TARGET_SYMLINK="/usr/local/bin/code" #### # Check if the symlink already exists if [ -L "$TARGET_SYMLINK" ]; then echo "Symlink already exists. Removing it first." sudo rm "$TARGET_SYMLINK" fi # Create the symlink ln -snf "$VSCODE_BIN" "$TARGET_SYMLINK" echo "Symlink created: $TARGET_SYMLINK -> $VSCODE_BIN" # Verify symlink creation if [ -L "$TARGET_SYMLINK" ]; then echo "Symlink created successfully." else echo "Failed to create symlink." fi # create settings.json file for disabling updates # Define the path to the settings.json file >>>> NEW TEST SETTINGS_PATH="$USER_HOME/Library/Application Support/Code/User/settings.json" # Ensure the directory exists mkdir -p "$(dirname "$SETTINGS_PATH")" # JSON key and value to add/update KEY="update.showReleaseNotes" VALUE="false" # Check if the file exists; if not, create it with an empty JSON object if [ ! -f "$SETTINGS_PATH" ]; then echo "{}" > "$SETTINGS_PATH" fi # Add or update the setting using jq if command -v jq &> /dev/null; then jq --arg key "$KEY" --arg value "$VALUE" '.[$key] = $value' "$SETTINGS_PATH" > "${SETTINGS_PATH}.tmp" && mv "${SETTINGS_PATH}.tmp" "$SETTINGS_PATH" echo "Setting \\"$KEY\\": \\"$VALUE\\" added/updated in $SETTINGS_PATH" else echo "jq is not installed. Please install jq to use this script." exit 1 fi # Set owner and group to the logged-in user and 'staff' for the application in /Applications open -a /Applications/Visual\\ Studio\\ Code.app sleep 5 chown -R $loggedInUser:staff "/Applications/Visual Studio Code.app" chown $loggedInUser:staff ~/Library/Caches/com.microsoft.VSCode.ShipIt exit 0
I am using this script, please ignore the part with the settings.json because this is not my preferred target. I would let install the user the update when its available.
Maybe someone has a solution for this.
I know, that i can create the symlink after visual studio code is installed through jamf mac apps (in self service) with an smartgroup which is scoping the right policy after vscode installation was updated to jamf pro, but the issue here is, that the installation of an mac app via jamf pro is not always updated instantly to jamf pro.
howie_isaacks
Forum|alt.badge.img+23
  • January 14, 2025
Check out Installomator.
https://github.com/Installomator/Installomator
Not only can it be used to run the initial install, but it can also be used for updating apps. It can alert users that an app needs to quit to be updated. I have used it a lot for updates and it is currently what I use to install several of our standard build apps. The latest version of the software is always installed. The documentation explains how you can use Installomator for updates.
Jacek_ADC
  • January 15, 2025
@howie_isaacks thank you for this, i am already using insallomator for some other apps an be using it "on an emergency basis" for the updates also for vscode. But this is not really what i want achieve for vscode updates.
  • August 11, 2025
I am deployed via Mac Apps and the JAMF App Catalog. Its a real problem with users getting updates and requiring Admin rights.
This is not sustainable in a secure environment.
JPS4R
  • August 12, 2025
One workaround would be to create a package which installs the app in a user-writable location such as /Users/Shared/Applications or /Applications/Microsoft (you’ll need to set the folder owner to the current user in your package postinstall script). VS Code will then be able to update itself with standard user privileges. Since user data (including extensions) sit in ~/.vscode it makes no difference where the application is located.
This has several drawbacks but it has been efficient and user-transparent as long as the user has the app icon in Dock or use Spotlight to launch apps.
  • August 12, 2025
I use Composer to create the installer pkg.  In composer make sure you have it in /Applications and then drag the new VSCode.pkg in the spot and make sure to clone the permissions and then create the .pkg and put it in the repositoty and no admin needed for the user to open the application.
  • August 13, 2025
I’m using Microsoft’s own script and setting the autoupdate to false.  Install VS Code
Wiebmer
  • August 13, 2025
We are using the Mac Apps feature to update Microsoft Visual Studio Code. It works very well. Admin rights have been removed from all our users..
