Google Secure LDAP Integration - Groups not associating
  • January 15, 2025
  • 30 views
jamf-42
testing Google Secure LDAP integration (Cloud Identity Providers)
I can lookup a user and it returns the user, but not the groups associated to the user.
I can lookup a group, but no users are associated.
Everything is configured as per this https://learn.jamf.com/en-US/bundle/jamf-pro-documentation-current/page/Google_Secure_LDAP_Integration.html
LDAP is configured for the domain in Workspace
Can someone who has this working shed some light!
_Daley
  • January 17, 2025
As far as I can tell, in the testing window you'd have to look for a group and a user, and it will tell you if they are in the group. I think this is expected behavior. - Or are you running into any other issues?
jamf-42
  • January 23, 2025
the issues is, user John Smith is in a memeber of Workspace groups, when you do a test lookup. it returns the user data, but has no groups.. and if you lookup a group that John Smith is in.. the group returns no users..
