Unable to join Google Meets for BYOD if per-app VPN is enabled
  • January 21, 2025
  • 28 views
Hi community,
I running into a strange behaviour for Google Meets on our BYOD deployment for iOS devices.
I have configured per App VPN as I did for all other BYOD apps in combination with Jamf Trust ZTNA.
Whenever I want to join a call, I am not able to join it.
When I remove the per-app VPN in the app's configuration then I am able to join.
Is there something I am missing or constraints to be considered?
Maybe there is a tweak to this?
agungsujiwo
  • January 22, 2025
Hi @hmn
You can check whether your VPN is in one of the Google restrictions, here is the list
https://support.google.com/a/answer/2891389?sjid=9012733968295039451-AP
if not, you can check the configuration in the VPN whether there are any settings that block access to Google Meet
  • February 3, 2025
Hi @hmn
HI @agungsujiwo thank you for your response. Well, we are using Jamf Security Cloud as VPN / ZTNA for both Macs and iPhones. There is no issue with institutional iPhones that use global VPN, same for Macs. Only on per app vpn the issue happens. So I would assume that it's not a google issue.
