Prevent user from setting parental controls AppleTV
  • February 10, 2025
  • 18 views
Hey Guys,
Is there any way to block the ability to set parental control passwords on an AppleTV? People have been setting passcodes on the devices and it is really annoying to wipe them every time to reset the code. Cant seem to find any info about this.
Thanks
1 reply
agungsujiwo
  • February 11, 2025
Hi @MaxxShearey ,
I haven't found a direct setting for the Parental Control you mentioned,
but you can try adjusting the hidden Settings menu on Apple TV to prevent unauthorized access.
Some apps not allowed or only some apps allowed
Based on the capture above, the Settings menu will be hidden, but other apps will remain visible on the Apple TV home screen.
Here is a list of Bundle IDs that you can use on Apple TV.
https://support.apple.com/id-id/guide/deployment/depcdd66fe58/web
