Attempting to manage Control Center, Any Options?
  • February 24, 2025
  • 0 replies
  • 34 views
Hey, Let me know if this is the wrong area to post in. Essentially we are attempting to disable Siri and its "Listen For" option. Unfortunately it seems we can only disable siri but if "Listen For" was enabled prior to disabling siri it still allows for the pop-ups saying "you dont have permission". We have been able to supress/kill the pop-ups as a temp fix for the time being though we notice the Siri icon in the top right of the menu bar is still there.
While you can manually get rid of that icon in the Control Center, We have yet to find much if any information or option to control the control center options and remove that icon through Jamf Pro's Config profiles as of yet.
My question is, Is there any way to remove a menu bar icon even if its with like a script or anything or even a way to manage the Control center through jamf just yet?
