Renew Tomcat SSL Certificate on Prem
  • February 28, 2025
  • 91 views
Hello Guys,
We are using Jamf Pro as an on prem. Tomcat ssl certificate's expires very soon.I did renew the ssl  new certificate than restart tomcat service. But users were not able to connect to self service.
Actually I deploy the new certificate to clients via  config. profile. I can see the current new Certificate in the keychain.
For testing, test device was connected to self service when I set the new certificate to always trust.
Best answer by AJPinto
Your problem is you used an invalid TLS certificate. TLS Certificates cannot be valid for more than 397 days, this term was put into place in 2020, and 2028 is just a wee bit longer than 13 months.
I recommend you put your old certificate back in place and call Jamf for guidance.
1 reply
AJPinto
  • February 28, 2025
