Enrolling macbook to JamfPro via Script
  • March 6, 2025
  • 10 replies
  • 55 views
Calling all jamf script superheroes...
I am a newbie to scripting, I want to make a script to enroll computers to JamfPro and then add the computer to a specific static group. Could any one please share/help if you have a working script handy?
I managed to make one but I am stuck with downloading the CA and enrollment profile config files. If I managed to download those two config files, I have to install it manually by clicking them and then the script continues and moves the computer to a specific static group, then a binding profile is pushed and the computer get binded to local AD.
@greatkemo Is this a piece of cake for you?
Thanks
jamf-42
  • 744 replies
  • March 6, 2025
you enrol Macs via ADE / ABM or invite <- don't do that.. anything else is a hack and is 'a very bad idea'
oh.. and never use static groups.. there be madness (and an overhead)
sdagley
  • 3567 replies
  • March 6, 2025
I'll 2nd @jamf-42 comment on enrollment (there can be use cases for Static Groups :-) ) and add that it is by design that you cannot script the installation of the CA and enrollment Configuration Profile because Apple considers both of those to be user privacy issues.
AJPinto
  • 2803 replies
  • March 6, 2025
Just to also toss my 2 cents in here. You can’t enroll devices via script anymore, apple broke that with macOS 10.15 several years back.
As far as the Static groups, that can done with API but depending on what you are needing and why it may not be worth the effort and could be better served with a smart group. AD binding is also not a good idea with macOS for most use cases.
In the end, what are you trying to accomplish? There may be another way to get where you need to be.
  • 13 replies
  • March 10, 2025
Actually, thats the practice here, technical team manually enrolls the macs and bind to domain. I am trying to make their life easy by making this process at least 80% less manual.
  • 13 replies
  • March 10, 2025
Actually my idea is (also what am trying to do is) a script which downloads the CA certificate and MDM certificate, our team will install it and then the computers get enrolled to MAC and added to a static group which will be mentioned in the script.
Below is the script am working on.. Your help is fixing this script is highly appreciated..
# Jamf Pro Server details
JAMF_URL="https://JSS-URL"
API_USER="USERNAME"
API_PASS="PASSWORD"
# Define Static Groups and their IDs
declare -A STATIC_GROUPS
STATIC_GROUPS=(
["macOS Update test group 1"]="233" # Replace with actual Group ID
["macOS Update test group 2"]="239" # Replace with actual Group ID
["Test"]="228" # Replace with actual Group ID
# Prompt user to select a Static Group
echo "Select a Static Group to add the computer:"
select GROUP_NAME in "${!STATIC_GROUPS[@]}"; do
if [[ -n "$GROUP_NAME" ]]; then
STATIC_GROUP_ID="${STATIC_GROUPS[$GROUP_NAME]}"
echo "Selected Group: $GROUP_NAME (ID: $STATIC_GROUP_ID)"
break
echo "Invalid selection. Please choose a valid group."
done
# Get the serial number of the Mac
SERIAL_NUMBER=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}')
# Enroll the Mac (Using MDM profile download & install)
echo "Downloading MDM profile for enrollment..."
curl -k -o /tmp/MDMProfile.mobileconfig "$JAMF_URL/mdm/EnrollmentProfile.mobileconfig"
echo "Installing MDM Profile..."
profiles install -path /tmp/MDMProfile.mobileconfig
# Wait for the computer to appear in Jamf Pro
echo "Waiting for computer to register in Jamf Pro..."
sleep 60 # Adjust if needed
# Get the Computer ID from Jamf API
COMPUTER_ID=$(curl -s -u "$API_USER:$API_PASS" -X GET "$JAMF_URL/JSSResource/computers/serialnumber/$SERIAL_NUMBER" -H "Accept: application/xml" | xmllint --xpath "//computer/general/id/text()" -)
# Add Computer to Selected Static Group
if [[ -z "$COMPUTER_ID" ]]; then
echo "Error: Could not retrieve Computer ID. Ensure the device is enrolled."
exit 1
echo "Adding computer to Static Group: $GROUP_NAME..."
XML_DATA="<computer_group><computer_additions><computer><id>$COMPUTER_ID</id></computer></computer_additions></computer_group>"
curl -s -u "$API_USER:$API_PASS" -X PUT "$JAMF_URL/JSSResource/computergroups/id/$STATIC_GROUP_ID" \\
-H "Content-Type: application/xml" \\
-d "$XML_DATA"
echo "Computer successfully added to $GROUP_NAME!"
Thanks a lot!
jamf-42
  • 744 replies
  • March 10, 2025
API_USER="USERNAME"
API_PASS="PASSWORD"
STATIC_GROUPS=(
break
done
exit 1
-d "$XML_DATA"
Thanks a lot!
why? this is not how you enrol devices?
its a bad idea from the start..
this would not pass any basic security check..
note that the API is not designed and should not be run on the endpoint.. thats not what its for..
sdagley
  • 3567 replies
  • March 10, 2025
API_USER="USERNAME"
API_PASS="PASSWORD"
STATIC_GROUPS=(
break
done
exit 1
-d "$XML_DATA"
Thanks a lot!
@BlackTiger You seem to be working from some very outdated information about enrolling Macs. As @jamf-42 originally pointed out you really want to have your Macs in ABM/ASM and enroll them via ADE. If you're not enrolling them via ADE they you do not have full control over them.
Your scripting information is also out of date (as indicated by the use of basic authentication is no longer supported for Jamf API calls) and as also mentioned by @jamf-42 Jamf does not recommend calling the API from arbitrary endpoints, it's intended to be used more as a management/admin tool.
You also mentioned binding Macs to AD. What is your use case for this? AD binding is generally discouraged, and may be of no practical benefit (and it's something that most
  • 13 replies
  • March 11, 2025
@sdagley and @jamf-42 Appreciate your replies. I wish I could change this. I recently joined a new workplace (school) and this is the procedure they follow, manual enrollment to Jamf and AD binding. We have Jamfpro on-prem and not cloud. We don't have ABM/ASM in place because when they purchase an app with one appleID they can push it to multiple devices, I think with ABM/ASM it wont be possible.
I don't see a point binding to AD neither, I had a chat with my teammate and he said they do it because when students print they can release it with their ID card because the printer recognizes their AD name. I just wanted to do this to reduce the workflow for the team. If AD binding is not needed then whats the best way for the students to print and release their prints with their ID? Their ID got the 4 digit code to unlock the printer and release the print.
sdagley
  • 3567 replies
  • March 11, 2025
@BlackTiger There's nothing about using ASM that precludes using the same Apple Account on multiple Macs to license a paid App Store app but that is definitely violation of Apple's Terms and Conditions so you might want to try persuading school management this would be a good time to correct that. Using ASM would definitely make it easier to deploy non-paid App Store apps via Jamf Pro.
I'd suggest checking with your printer management vendor to see what they recommend for Mac configuration. It may be possible to configure the printer agent without binding to AD.
  • 13 replies
  • March 12, 2025
Thank you everyone for your inputs, I will discuss this internally and will try to change the workflow here. Have a good one...
