Persistent "Registration Required" Notification with Jamf Connect & MS Entra
  • March 19, 2025
  • 104 views
Hello everyone,
We are currently facing an issue with Jamf Connect where some users keep receiving the notification:
"Registration required - Register with your Microsoft Entra password on your Mac."
Our Setup:
  • Jamf Connect installed manually on affected devices
  • Devices manually registered in Company Portal
  • MacOS 15.3.1
  • Latest version of Jamf Connect & Company Portal
  • Devices appear as compliant in MS Entra
  • Devices in Jamf Managed &Supervised
  • uniqueIdentifier" : "97BD-IUHGLD-LIUGHW7G-.....ETC."
  • FileVault 2 Partition Encryption State:Encrypted
Troubleshooting Steps Taken:
  1. Verified compliance status in MS Entra
  2. Deleted the device from MS Entra and re-registered
  3. Cleared keychain entry:
    /Users/testuser/Library/Keychains/65649DB6-A89B14CE16E0E
  4. Ran a script to reset Entra registration, which:
    • Quits Company Portal
    • Deletes related preference files and saved states
    • Removes keychain entries and identity preferences
    • Deletes the MS-ORGANIZATION-ACCESS certificate
    • Reinstalls Company Portal
  5. After a Mac restart, users go through the registration process again, but the notification reappears after a few hours.
Has anyone encountered this issue before?
  • Is there an additional cache, token, or certificate that should be removed?
  • Could Conditional Access policies or Jamf Connect settings be causing this loop?
Any insights or suggestions would be greatly appreciated!
Thanks in advance!
#!/bin/bash ############################################################################################################## # Reset Entra ID Registration # # # #---------------------------------------------- # Vers. 2.0, 08.07.2024 #---------------------------------------------- # ############################################################################################################## # Variables # $4 Custom Trigger für Jamf Policy "Install Company Portal" jamfTrigger1="main_companyportal" #jamfTrigger2="intune_Register" # Get the username of the currently logged in user loggedInUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }') # Get the user's home directory homeDir=$(dscl . read /Users/$loggedInUser NFSHomeDirectory | awk '/\\/Users/{print $2}') #-------------------------------------------------------------------------------------------------------------- if [[ $(pgrep "Company Portal") != "" ]]; then echo "Quitting Company Portal" killall "Company Portal" fi fileArray=( "/Applications/Company Portal.app/" "${homeDir}/Library/Application Support/com.microsoft.CompanyPortal.usercontext.info" "${homeDir}/Library/Application Support/com.jamfsoftware.selfservice.mac" "${homeDir}/Library/Saved Application State/com.jamfsoftware.selfservice.mac.savedState" "${homeDir}/Library/Saved Application State/com.jamf.management.jamfAAD.savedState/" "${homeDir}/Library/Saved Application State/com.microsoft.CompanyPortal.savedState" "${homeDir}/Library/Preferences/com.microsoft.CompanyPortal.plist" "${homeDir}/Library/Preferences/com.jamfsoftware.management.jamfAAD.plist" "${homeDir}/Library/Cookies/com.microsoft.CompanyPortal.binarycookies" "${homeDir}/Library/Cookies/com.jamf.management.jamfAAD.binarycookies" ) for i in "${fileArray[@]}"; do if [[ -e $i ]]; then echo "Deleting file $i" rm -rf "$i" fi done passwordItemAccountsArray=( 'com.microsoft.workplacejoin.thumbprint' 'com.microsoft.workplacejoin.registeredUserPrincipalName' 'com.microsoft.workplacejoin.deviceName' 'com.microsoft.workplacejoin.thumbprint' 'com.microsoft.workplacejoin.deviceOSVersion' 'com.microsoft.workplacejoin.discoveryHint' ) for i in "${passwordItemAccountsArray[@]}"; do itemCheck=$(/usr/bin/security find-generic-password -a $i | grep svce) #> /dev/null 2>&1) if [[ "$itemCheck" != "" ]]; then echo "Deleting Password Item $i" /usr/bin/security delete-generic-password -a $i ${homeDir}/Library/Keychains/login.keychain-db > /dev/null 2>&1 fi done # There may be more than one of 'com.microsoft.workplacejoin.devicePatchAttemptTimestamp' so using a while loop to get them all devicePatchAttemptTimestamp=$(/usr/bin/security find-generic-password -a 'com.microsoft.workplacejoin.devicePatchAttemptTimestamp' | grep svce) while [[ $devicePatchAttemptTimestamp != "" ]]; do /usr/bin/security delete-generic-password -a 'com.microsoft.workplacejoin.devicePatchAttemptTimestamp' ${homeDir}/Library/Keychains/login.keychain-db > /dev/null 2>&1 devicePatchAttemptTimestamp=$(/usr/bin/security find-generic-password -a 'com.microsoft.workplacejoin.devicePatchAttemptTimestamp' | grep svce) done identityPrefArray=( 'com.jamf.management.jamfAAD' 'com.microsoft.CompanyPortal' 'com.microsoft.CompanyPortal.HockeySDK' 'enterpriseregistration.windows.net' 'https://device.login.microsoftonline.com' 'https://device.login.microsoftonline.com/' 'https://enterpriseregistration.windows.net' 'https://enterpriseregistration.windows.net/' ) for i in "${identityPrefArray[@]}"; do itemCheck=$(/usr/bin/security find-generic-password -l $i | grep svce) if [[ $itemCheck != "" ]]; then echo "Deleting Identity Preference $i" /usr/bin/security delete-generic-password -l $i ${homeDir}/Library/Keychains/login.keychain-db > /dev/null 2>&1 fi done certCheck=$(/usr/bin/security find-certificate -a -Z | grep -B 9 "MS-ORGANIZATION-ACCESS" | grep "SHA-1" | awk '{print $3}') if [[ $certCheck != "" ]]; then echo "Deleting $certCheck" /usr/bin/security delete-identity -Z "$certCheck" -t ${homeDir}/Library/Keychains/login.keychain-db > /dev/null 2>&1 fi # Install Company Portal /usr/local/bin/jamf policy -event $jamfTrigger1
  • March 19, 2025
 issue with MS Entra
  • March 19, 2025
the times that I have seen that in our shop is when they are either missing the WPJ key or it is corrupted.  If you cannot manually delete it from the Keychain then they might need to have the keychain rebuilt...
