What is the best way to superseed a package?
  • March 19, 2025
  • 5 replies
  • 52 views
Hello,
We have been doing different things for different packages.
But what is the best way to superseed a policy/package? As in if a software releases a new version and you want to update the version you are using right now to the newer version.
Mostly we have been creating a new package and policy, and then deleted the old package and policy.
Best answer by mvu
The clone button is your friend. I tend not to flush any logs in case I want to see logs. But I'll do a weekly clean-up on very old policies and packages.
Someone also mentioned it, but Jamf App Catalog or Installomater are good options if your organization allows. Great options if you're not tied to tight version control.
PaulHazelden
  • March 19, 2025
I generally upload a new version of the package, usually with the version number added to the name. And then replace the package in the poilcy. When I am ready to go, I simply view the logs and hit the Flush All button, and the policy will rerun with the new package.
I keep old package versions for a while, just in case I need to revert back.
Shyamsundar
  • March 19, 2025
Try using the Jamf App Catalog for updating as you don't need any Packages.
mvu
Forum|alt.badge.img+21
  • March 19, 2025
  • March 19, 2025
Thanks for the suggestions. I guess we will have to use one of the suggested options with either replacing the package in the policy or duplicating the policy with the new package
Since, at the moment we can't use the Jamf App Catalog since we have on-prem Jamf (but we are probably gonna change to cloud when it's time to renew).
We have been using Installomator for some software, it is a neat script. It's just some softwares aren't in it unfortunately.
mvu
  • March 19, 2025
Depending on the software title/s, you might be able to get them added to Installomater.
