How do I delete a launch daemon using a script?
  • March 21, 2025
  • 4 replies
  • 230 views
howie_isaacks
Forum|alt.badge.img+23
I have been working on a policy that will create a temporary admin account. A launch daemon gets installed and launched to handle the account deletion. Once the alotted time has elapsed, I see the account and its home folder get deleted. I see that the launchd process is no longer running. Everything works exactly as intended, but the launch daemon does not get deleted. I can manually run a command such as "sudo rm /Library/LaunchDaemons/com.my.launchdaemon.plist" and that works perfectly. The launch daemon triggers another Jamf Pro policy to run that deploys a script that runs the account deletion, deletes the home folder, unloads the launch daemon and then is supposed to delete the launch daemon. A moment ago, I commented out all the steps except the launchdaemon unload and deletion, and watched as the script deleted the launch daemon! Below are all the steps that the script runs.
#!/bin/zsh # Delete the Rescue Admin account and its home folder echo "Removing Rescue Admin account" dscl . -delete /Users/rescueadmin echo "Deleting home folder" rm -rf /Users/rescueadmin # Unload and delete the Rescue Admin launch daemon echo "Unloading launchdaemon" launchctl bootout system /Library/LaunchDaemons/com.cbre.RescueAdmin.plist echo "Deleting launchdaemon" rm -f "/Library/LaunchDaemons/com.cbre.RescueAdmin.plist"
 I don't understand why removing all the previous steps in the script allows the launch daemon to get deleted. I know there are other temporary admin account solutions but I wanted to create one myself. It's only the launch daemon deletion that won't work. How can I delete the launch daemon?
Best answer by sdagley
OK. The launch daemon does get unloaded. I see that when I run launchctl list. It just doesn't get deleted. I will modify the bootout command as you mentioned.
I should have added that because the process for the LaunchDaemon is still running the .plist for it is still "busy" and won't go away until the process is killed.
sdagley
  • March 21, 2025
@howie_isaacks Your bootout command is wrong.
Should be
launchctl bootout system/com.cbre.RescueAdmin
(or whatever the label is for the LaunchDaemon)
howie_isaacks
  • March 21, 2025
Should be
sdagley
  • March 21, 2025
howie_isaacks
  • March 21, 2025
You're right! And right after I responded to you a moment ago, I realized that plist won't get deleted if it's still in use. Here's what has worked twice over the last few minutes. I removed the unload and delete steps from the script that handles the account deletion. I added those steps to files and processes in the same policy that is running the script that deletes the admin account. That worked! I set the launch daemon to launch this process after 2 minutes. When I put this into production, I will set it to 15 or 20 minutes.
