we recently acquired a Jamf Pro license and wanted to build a update ring for certain softwares.
Since Cisco Anyconnect is not available in Patch Management i thought i'll make a feature request.
you can use title editor to add Cisco Secure Client
With my Jamf ID?
With my Jamf ID?
I mean do i login to Title Editor with my Jamf ID?
@HerrIT this is a good request.
If you want to request this I recommend going to https://ideas.jamf.com/ideas/PCAP-I-152 and voting for the request there to have Cisco AnyConnect added, which includes Cisco Secure Client.
Any new requests or voting on existing ideas all happen at https://ideas.jamf.com/ideas.
@BookMac is right.  Title Editor would be a good idea to use.  You can find more details here:
What is Title Editor?
Setting up Title Editor in Jamf Pro
Manual Creation - Title Editor Documentation
Hopefully this will get you going.  Feel free to reach out if you have any issues.
Your Jamf Success representative is also a helpful resource.
If you use Cisco ISE management to manage your VPN, why not use that to deploy your upgrade? You can configure a update policy with the Cisco profile so when the user logs into the VPN client it will automatically update.
I cant login with my Jamf ID in Title Editor. Did i miss something?
