CrowdStrike Falcon Sensor Extension Attributes
  • March 31, 2025
  • 436 views
Alvaro1337
Hi Jamf Nation Team,
We are currently working to deploy the Falcon Sensor in our system, but we need to monitor the sensor's status. Unfortunately, the Extension Attribute I was using is not gathering the necessary information.
Could you please help me if you have any that I can use:
Sensor Registration: Confirms whether the Falcon Sensor is correctly registered with the CrowdStrike cloud.
Sensor Operational Status: Checks if the Falcon Sensor service is running correctly on the endpoint.
Sensor Cloud Connectivity: Verifies that the sensor can successfully communicate with CrowdStrike’s cloud infrastructure.
Thank you!
Best answer by SlipStream
Within our environment, I put together some extension attributes for monitoring the status of the Falcon Sensor.
Below is the extension attributes I created within Jamf Pro, and the scripts needed for them:
CrowdStrike | Falcon Sensor | Agent ID
#!/bin/bash echo "<result>$(sudo /Applications/Falcon.app/Contents/Resources/falconctl stats | awk '/agentID:/ {print $2}')</result>"
CrowdStrike | Falcon Sensor | Customer ID
#!/bin/bash echo "<result>$(sudo /Applications/Falcon.app/Contents/Resources/falconctl stats | awk '/customerID:/ {print $2}')</result>"
CrowdStrike | Falcon Sensor | Installed
#!/bin/bash csfs=`ls /Applications | grep 'Falcon.app'` if [ "$csfs" != "" ]; then echo "<result>Installed</result>" else echo "<result>Not Installed</result>" fi rm -f "$csfs"
CrowdStrike | Falcon Sensor | Sensor Operational
#!/bin/bash echo "<result>$(sudo /Applications/Falcon.app/Contents/Resources/falconctl stats | grep "Sensor operational:" | awk '{print $3}')</result>"
CrowdStrike | Falcon Sensor | Version
#!/bin/bash FalconVersion=`defaults read /Applications/Falcon.app/Contents/Info.plist CFBundleShortVersionString` FalconVersionCheck=`"$FalconVersion" | grep "*does not exist"` if [ "$FalconVersionCheck" != "*does not exist" ]; then echo "<result>$FalconVersion</result>" else echo "<result>Not Installed</result>" fi rm -f "$FalconVersion" rm -f "$FalconVersionCheck"
The results of these extension attributes can then allow for all kinds of reports to be generated, to ensure all is working as you would want or expect for Falcon Sensor deployments.
I hope these help.
SlipStream
  • March 31, 2025
I hope these help.
Alvaro1337
  • March 31, 2025
I hope these help.
Thank you! I see the issue with the ones that I have now, appreciate your help!
blinvisible
  • February 11, 2026
Execution is slightly more efficient on stats queries by only returning the specific agent_info section, rather than all stats.
AgentID:
/Applications/Falcon.app/Contents/Resources/falconctl stats agent_info | /usr/bin/awk '/agentID:/ {print $2}'
CustomerID:
/Applications/Falcon.app/Contents/Resources/falconctl stats agent_info | /usr/bin/awk '/customerID:/ {print $2}'
Sensor Operational (also omits unnecessary grep):
/Applications/Falcon.app/Contents/Resources/falconctl stats agent_info | /usr/bin/awk '/Sensor operational:/ {print $3}'
Version is also available via stats, if you want the complete version number (“7.33.20503.0”), as opposed to the truncated one available in CFBundleShortVersionString (“7.33”):
/Applications/Falcon.app/Contents/Resources/falconctl stats agent_info | /usr/bin/awk '/version:/ {print $2}'
