Microsoft Edge browser default in the browser and adding bookmarks
  • April 12, 2025
  • 114 views
Hi All,
Does anybody know how to default the edge browser and also add bookmarks within Jamf Pro?
Thanks in advance
pete_c
  • April 12, 2025
To set as default, there are several tools available like utiutil, duti and swda - the last of which is still my go-to.
 https://github.com/RhetTbull/utitools
 https://github.com/Lord-Kamina/SwiftDefaultApps
To set bookmarks (called 'favorites' on Edge) you'll want to create and deploy a configuration profile using the keys and values as described in the Edge policy documentation:
 https://learn.microsoft.com/en-us/deployedge/microsoft-edge-policies#managedfavorites
If you're new to configuration profiles, check out iMazing Profile Editor:
 https://imazing.com/profile-editor
Remember to quit and reopen Edge after deploying changes to the profile - even though as a Chromium browser, you should be able to open "edge://policy" and chose Reload, not every key will be respected this way. Save versions as you develop the profile so you can easily revert when something breaks. Don't ever delete a computer-level profile from Jamf without setting its scope back to None first (or, better yet, just don't ever delete any computer-level profiles, just file them away in an Archive category etc).
czarmark
  • April 15, 2025
You can have a policy run a script to set the default browser, for example
#!/bin/sh # SetMicrosoftEdgeDefaultBrowser.sh # Script to check the currently logged in user and set Microsoft Edge to their default browser # Find out who the currently logged in user is CurrentUser=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' ) # Run open command as the currently logged in user to set Edge as the default browser su -l $CurrentUser -c "open /Applications/Microsoft\\ Edge.app/ --args --make-default-browser" exit 0
