Any idea what this means?
OSUpdateStatus - The software update request for this process was denied as another process is currently performing an operation. Please try again later.
On the affected device, what shows under the "history" tab when you view the Operating System history? I think that's when it's received more than one push to update the OS.
The "OSUpdateStatus" message indicates your operating system is currently busy with another software update or installation, preventing a new update request from starting. The solution is usually to wait for the ongoing process to finish and then try again. Restarting your computer might also resolve the issue by clearing any stuck update processes. If the problem persists, further troubleshooting of your operating system's update mechanism might be necessary.
