Nexthink deployment on sequoia
  • May 13, 2025
  • 8 replies
  • 135 views
SMR1
Since we upgraded to sequoia, we had to update our Nexthink version, because the install was failing on enrollments. After changing it and enrollig a sonoma device, it works and shows in nexthink. When we enroll a mac on sequoia, it looks like it installs on the device, but never shows in nexthink.
Mperez718
  • May 13, 2025
We had a similar issue when installing Nexthink on Sequoia devices. We had to update our PPPC configuration profile to give nexthink a missing permission.
SMR1
  • May 13, 2025
@Mperez718  Do you mind sharing how your originall PPPC setup?
Mperez718
  • May 13, 2025
Let me see if I have a copy of the OG .mobileconfig somewhere as I normally back them up before i make a change.
SMR1
  • May 13, 2025
I know the only thing we have in our current pppc is to allow nxtsvapp and that worked fine with sonoma and prior OS's. We also package the installer via composer and use a post install script for the install. I added the nxtcod to match what you had, but not having any luck with it reporting in the nexthink console. I'll do some more testing.
sdagley
  • May 13, 2025
@SMR1 I just checked our Nexthink PPPC settings, which are working on macOS Sequoia, and it's just SystemPolicyAllFiles Allow for nxtsvapp.
SMR1
  • May 13, 2025
@sdagley That's weird, curious why on our Mac's their not showing in the console. I'll do some more playing testing.
Do you use a post install script?
sdagley
  • May 13, 2025
Breaking the thread below to post a link to the official Nexthink docs on creating the needed Configuration Profile: https://docs.nexthink.com/platform/getting-started/planning-your-installation/installing-collector/macos-collector-references/installing-collector-profile-in-jamf-for-macos
sdagley
  • May 13, 2025
@SMR1 Our postinstall script is pretty basic:
#!/bin/sh ## postinstall InstallPath="/private/var/tmp/Nexthink" "$InstallPath/uninstaller" /usr/bin/cd "$InstallPath/csi.app/Contents/MacOS" "$InstallPath/csi.app/Contents/MacOS/csi" -address tenantname.nexthink.cloud \\ -tcp_port 443 \\ -key "$InstallPath/Customer Key.txt" \\ -engage enable -data_over_tcp enable \\ -ra_execution_policy signed_trusted_or_nexthink \\ -use_assignment enable # Sleep to allow time for the install process to complete /bin/sleep 10 # Delete the install files /bin/rm -rf "$InstallPath" exit 0 ## Success
