I'm use the Patch management to manage updates for Firefox ESR. The current Patch Management definition is handling both 115.x & 128.x. I am using the report to create a smart group to handle the updates via a Installomator policy to install Firefox ESR which is the 128.x version. The Patch Management report is reporting 115.x as the latest version ignoring the 128.x as part of the definition. Is there a way to modify the report so that people can choose the version they are looking for? I know that if 128.x updates next it will be the latest version as the definition goes by the release date of either 115.x or 128.x. This is causing annoyances in my user base as update is running daily in some cases. Is there anything that can be done? Thanks,
Be the first to reply!
