How to Block "Update Mac Automatically" Prompt During Setup Assistant?
  • June 9, 2025
  • 7 replies
  • 204 views
Hi all,
I’m looking for a way to block or skip the “Update Mac Automatically” screen that appears during the Setup Assistant (screenshot attached). Is there a way to suppress or bypass this screen using a configuration profile?
Any insight or guidance would be much appreciated!
sdagley
  • June 9, 2025
@user-MSmmWbbdFI That can be disabled by selecting the Software Update item under the Setup Assistant Options section of your PreStage Enrollment configuration. Items that are selected in that section will be skipped during Setup Assistant.
dletkeman
  • June 9, 2025
Here's how it looks for me.  Computers > PreStage Enrollments > [Name of Prestage Enrollment] > General.
It will be the last item.
I'm glad you mentioned this as I had forgot to update mine since Apple Intelligence came out.
  • June 9, 2025
Any on the fly control for macs that won't be pre-staged quite yet?  I haven't found that the recommended restrictions payload in a profile is successfully removing them (whether AI and Software Update are allowed or restricted) for a new or existing login.
easyedc
  • June 12, 2025
One thing to remember, you probably don't want users setting up stale OS's. I recommend the disabling checkbox to remove user choice for software updates frequency, but maybe check your setting for Minimum required OS Version to make sure they get enrolled as patched workstations.
  • June 12, 2025
Well from what I've seen, the issue pictured above in the OP doesn't occur on stale OS's. Its only happening on Sequoia macOS 15 in-place upgrades, unless the computer is provisioned through the new Sequoia pre-stage options of "skip Intelligence" and "skip Software Update".
dlondon
  • January 20, 2026
Does setting this in the prestage, work to disable the pop-up for machines already deployed?
@user-MSmmWbbdFI was asking if there’s a way to do this with a configuration profile and that is also what I’m looking for as well
agungsujiwo
  • January 20, 2026
Hi ​@user-MSmmWbbdFI ,
You can create a Setup Assistant skip profile ,
com.apple.SetupAssistant.managed > SkipKeys.
<key>SkipSetupItems</key>
            <array>
                <string>SoftwareUpdate</string>
            </array>
You can skip other Setup Assistant items as well. Please see the link below for the full list.
