JAMF System Admin Tools using SwiftDialog GUI [Upated!]
  • June 12, 2025
  • 79 views
Hey Gang,
Back again with some major improvements to my JAMF Admin tools.  The new v2 now supports API roles (not just ID & password), along with some other nice features:
  • Now you can backup your Smart & Static groups (with natural language context)
    • Smart group exports will show the conditions in the same way JAMF show the criteria
    • Static groups will export the members of the group
  • Create contact cards or compose emails to specific group members
  • JAMF Pro API Token support
As well as these existing items:
  • Backup Self service Icons
  • Retrieve / Clear failed MDM commands
  • Backup System scripts
  • Backup Computer EAs
  • Backup Configuration Profiles
Full details are on my GitHub site: https://github.com/ScottEKendall/JAMF-Pro-Scripts/tree/main/JAMFSystemUtilities
1 reply
Hello,
Thanks for share details.
Best Regard,
Theresa
