Hi folks,
i have a problem with the Apple Software Update Server. If i activate some updates in the server, next day the updates are disabled. First time i discovered this was on System 10.11 with Server 5.0.15. Then i have done a fresh install with 10.10 and 5.0.15 and it has worked a few weeks, but now it is not working anymore again. I think this is the same problem here https://discussions.apple.com/thread/7285512?start=0&tstart=0
Does anyone have any idea?
regards Lars
