Hello,
We are trying to push out the Follett Digital Reader application to our Macs and are wondering what is the best way to distribute Adobe Air? For Flash we pull out the PKG file and use that push out updates, but Air doesn't seem to have that type of install. Right now we just used Composer to capture the install and that seems to be working. Just wondering if there is a better method.
Thanks, Tim
