Software Update Server settings stuck.
  • March 31, 2015
  • 23 views
Hey all, so we recently moved away from a pair of Reposado servers to point our clients back out to Apple for their Software Update needs.
I have a client that is stuck with the old setting and I can't get it to check Apple SUS.
So the preferences for the SUS settings were being set by Managed Preferences.
I removed the MCX, then ran a script that deleted the /Library/Managed Preferences/ directory and called jamf -mcx to rebuild another others that might be needed (none are being used now)
I've run the jamf removeSWUSettings command and the softwareupdate --clear-catalog commands and still when I check for Software Updates it tries to connect to the local reposado server (which doesn't exist anymore.)
From what I can tell this is working just fine on most computers, but a few are being stubborn.
Any help or fresh ideas are welcome.
Best answer by cmarker
So yeah, on a whim I created a new Managed Preference with the Software Update "level" set to Unmanaged, which worked perfectly.
Yay?
1 reply
  • March 31, 2015
Yay?
