Apps deploying but JSS not listing as complete - even after recon
  • March 12, 2013
  • 56 views
ImAMacGuy
Forum|alt.badge.img+23
I've noticed on a few systems that they are checking in, they have the current binary, proper accounts enabled, etc etc. But when I push software such as Flash or Java or ... just about anything, Casper remote will report successful, but when I go and check in teh JSS it shows as still not there.
This one I've logged in locally and done a sudo jamf recon verbose and it goes through and does everything... then... quits. No error, no nothign.
Successfully installed Adobe Flash Player.pkg. Unmounting file server... Running Recon... Retrieving inventory preferences from https://... Finding extension attributes... Locating hard drive information... Locating hardware information (Mac OS X 10.8.2)... Executing Unix applications... Locating accounts... Locating application details... ushofml312683:~ $ Finished.
I've tried re-enrolling with -prompt and -verbose and it gets to teh recon and stops again...
:~ $ sudo jamf enroll -verbose -prompt JSS Username: JSS Password: SSH Username: SSH Password: Downloading the JSS CA Certificate... verbose: Successfully downloaded the certificate. verbose: Adding the certificate to the System keychain... verbose: Successfully added the certificate to the System keychain... There were (1) previous JAMF device identities found on this computer. Removing... This computer was successfully enrolled to the JSS with the following device certificate: " Retrieving inventory preferences from https://server:8443/... Finding extension attributes... verbose: Running script for the extension attribute Admin Report verbose: Running script for the extension attribute Boot Volume Free Space verbose: Running script for the extension attribute com.apple.screensaver - Require Password verbose: Running script for the extension attribute Flash Version verbose: Running script for the extension attribute Java Version verbose: Running script for the extension attribute Last User verbose: Running script for the extension attribute OmniGraffle Serial Number verbose: Running script for the extension attribute Outlook 2011 Identities Folder Size verbose: Running script for the extension attribute Pintsized.A Backdoor verbose: Running script for the extension attribute QuickTime Pro Serial Number verbose: Running script for the extension attribute Sophos - Virus Definition Date verbose: Running script for the extension attribute Sophos - Virus Definition Version verbose: Running script for the extension attribute VMware - Virtual Machine List verbose: Running script for the extension attribute VMware Fusion Serial Number verbose: Running script for the extension attribute Wacom Tablet Locating hard drive information... verbose: Finding CoreStorage information... Locating hardware information (Mac OS X 10.8.2)... Executing Unix applications... verbose: Checking AD status... Locating accounts... verbose: Finished with user. verbose: Finished with user. Locating application details... verbose: Found app: /Applications/Adobe/Adobe Help.app verbose: Found app: /Applications/Adobe/Adobe Widget Browser.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Built-in/Preflight.acroplugin/Versions/A/Resources/Droplet.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/MacOS/Updater/Adobe Acrobat Updater Helper.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/MacOS/Updater/Adobe Acrobat Updater.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Support/Acrobat Uninstaller.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Support/Acrobat Uninstaller.app/Contents/Frameworks/adobe_oobelib/adobe_licutil.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Support/AdobeResourceSynchronizer.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Support/Assert.app verbose: Found app: /Applications/Adobe Acrobat XI Pro/FormsCentral For Acrobat.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Adobe Analysis Server.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Adobe QT32 Server.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/aerendercore.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/aeselflink.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Required/AdobeQTServer.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/GPUSniffer.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/ImporterREDServer.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe After Effects CS6/Adobe After Effects Render Engine.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/dvaaudiofilterscan/dvaaudiofilterscan.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/GPUSniffer.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/adobe3dandvideoserver.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Photo Downloader.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Download Assistant.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Resources/LogTransport2.app verbose: Found app: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Resources/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Edge Animate/Adobe Edge Animate.app verbose: Found app: /Applications/Adobe Edge Animate/Adobe Edge Animate.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Edge Animate/Adobe Edge Animate.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Edge Animate/Adobe Edge Animate.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Edge Animate/Adobe Edge Animate.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Edge Animate/Adobe Edge Animate.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Edge Animate/Adobe Edge Animate.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/Adobe QT32 Server.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Required/AdobeQTServer.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/Frameworks/PhotoshopServer.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/GPUSniffer.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/ImporterREDServer.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app verbose: Found app: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app verbose: Found app: /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/Adobe Flash Builder 4.6.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/eclipse/Eclipse.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/player/mac/11.1/Flash Player Debugger.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/player/mac/11.2/Flash Player Debugger.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/lib/nai/lib/naib.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/sdks/4.6.0/runtimes/air/mac/Adobe AIR.framework/Versions/1.0/Resources/Template.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/utilities/Adobe Flash Builder 4.6 Plug-in Utility.app verbose: Found app: /Applications/Adobe Flash Builder 4.6/utilities/Adobe Flash Builder 4.6 Plug-in Utility.app/Contents/Resources/Adobe Flash Builder 4.6 Plug-in Utility.app verbose: Found app: /Applications/Adobe Flash CS6/Adobe Flash CS6.app verbose: Found app: /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Flash CS6/AIR3.2/lib/nai/lib/naib.app verbose: Found app: /Applications/Adobe Flash CS6/AIR3.2/runtimes/air/mac/Adobe AIR.framework/Versions/1.0/Resources/Template.app verbose: Found app: /Applications/Adobe Flash CS6/AIR3.4/lib/nai/lib/naib.app verbose: Found app: /Applications/Adobe Flash CS6/AIR3.4/runtimes/air/mac/Adobe AIR.framework/Versions/1.0/Resources/Template.app verbose: Found app: /Applications/Adobe Flash CS6/Common/Configuration/Simulator/SimController.app verbose: Found app: /Applications/Adobe Flash CS6/Players/Debug/Flash Player Debugger.app verbose: Found app: /Applications/Adobe Flash CS6/Players/Flash Player.app verbose: Found app: /Applications/Adobe Flash CS6/Players/Release/Flash Player.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Required/AdobeQTServer.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Illustrator CS6/Scripting.localized/Sample Scripts.localized/AppleScript.localized/Analyze Documents.localized/Analyze Documents.app verbose: Found app: /Applications/Adobe Illustrator CS6/Scripting.localized/Sample Scripts.localized/AppleScript.localized/Calendar.localized/Make Calendar.app verbose: Found app: /Applications/Adobe Illustrator CS6/Scripting.localized/Sample Scripts.localized/AppleScript.localized/Contact Sheet Demo.localized/Contact Sheets.app verbose: Found app: /Applications/Adobe Illustrator CS6/Scripting.localized/Sample Scripts.localized/AppleScript.localized/Export Flash Animation.localized/Export Flash Animation.app verbose: Found app: /Applications/Adobe Illustrator CS6/Scripting.localized/Sample Scripts.localized/AppleScript.localized/Web Gallery.localized/Web Gallery.app verbose: Found app: /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app verbose: Found app: /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Adobe QT32 Server.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Required/AdobeQTServer.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/PhotoshopServer.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/ImporterREDServer.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/MediaIO/codecs/SurCode.framework/Versions/A/Resources/SurCodeServer.app verbose: Found app: /Applications/Adobe Muse.app verbose: Found app: /Applications/Adobe Muse.app/Contents/Resources/META-INF/AIR/extensions/com.adobe.cts.NativeExtension/META-INF/ANE/MacOS-x86/LogTransport2.app verbose: Found app: /Applications/Adobe Muse.app/Contents/Resources/META-INF/AIR/extensions/com.adobe.cts.NativeExtension/META-INF/ANE/MacOS-x86/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/required/AdobeCrashRealTimeNotification.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/hlcrashprocessor.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Droplet Template.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/logtransportlaunch.app verbose: Found app: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/logtransportlaunch.app/Contents/frameworks/LogTransport.framework/Versions/A/support/LogTransport.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/Adobe QT32 Server.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Required/AdobeQTServer.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/Frameworks/PhotoshopServer.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/GPUSniffer.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/ImporterREDServer.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/MacOS/ScriptAlign.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Prelude CS6/Adobe Prelude CS6.app/MediaIO/codecs/SurCode.framework/Versions/A/Resources/SurCodeServer.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Adobe QT32 Server.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/Adobe Crash Reporter.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Required/AdobeQTServer.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PhotoshopServer.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/GPUSniffer.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/ImporterREDServer.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/LogTransport2.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/LogTransport2.app/Contents/MacOS/HLCrashProcessor.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/ScriptAlign.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/PProHeadless.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Required/LogTransportLaunch.app/Contents/Frameworks/LogTransport.framework/Versions/A/Support/LogTransport.app verbose: Found app: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/MediaIO/codecs/SurCode.framework/Versions/A/Resources/SurCodeServer.app verbose: Found app: /Applications/Adobe Reader.app verbose: Found app: /Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater Helper.app verbose: Found app: /Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater.app verbose: Found app: /Applications/Adobe Reader.app/Contents/Support/AdobeResourceSynchronizer.app verbose: Found app: /Applications/Adobe Reader.app/Contents/Support/Assert.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app verbose: Found app: /Applications/Adobe SpeedGrade CS6/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app/Contents/MacOS/Adobe SpeedGrade CS6.app :~ $
Best answer by bentoms
Have a nose @ https://jamfnation.jamfsoftware.com/discussion.html?id=5775
bentoms
Forum|alt.badge.img+35
  • March 12, 2013
  • March 13, 2013
Yep, this is the Adobe CS6 SpeedGrade bug…
I have not got CS6 installed on my machine right now, so I can't check the exact path.
Take a look inside the Adobe SpeedGrade application (Control-Click show application Contents)
inside Contents/MacOS .. next to the binary you will see an alias to CS6 SpeedGrade
It's that alias, thats causing JAMF recon to go around and around and around in circles.
- The solution is to delete that internal alias to CS6 SpeedGrade.app
ImAMacGuy
  • March 13, 2013
awesome! it worked!
thank you!
